My Clam AV stops every hour and restarts sometimes. I tried upgrading from the current Virtualmin version .99 to Epel .100 but it fails:
Error: Package: clamd-0.100.1-2.el6.x86_64 (epel)
Requires: clamav = 0.100.1-2.el6
Installed: clamav-0.99.2-3.el6.x86_64 (@epel)
clamav = 0.99.2-3.el6
Available: clamav-0.98.5-1.el6.x86_64 (virtualmin)
clamav = 0.98.5-1.el6
Requires: libclammspack.so.0()(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
I saw a post about checking beancounters for errors. There are errors, but not sure what I have to do to fix:
Version: 2.5
uid resource held maxheld barrier limit failcnt
10086860: kmemsize 173778584 175853568 9223372036854775807 9223372036854775807 0
lockedpages 18133 18258 9223372036854775807 9223372036854775807 0
privvmpages 1391623 1455453 9223372036854775807 9223372036854775807 0
shmpages 566 566 9223372036854775807 9223372036854775807 0
dummy 0 0 9223372036854775807 9223372036854775807 0
numproc 212 240 32567 32567 0
physpages 1043631 1046709 1048576 1048576 1106
vmguarpages 0 0 1048576 9223372036854775807 0
oomguarpages 973152 973152 1048576 9223372036854775807 738
numtcpsock 48 49 9223372036854775807 9223372036854775807 0
numflock 223 224 9223372036854775807 9223372036854775807 0
numpty 0 0 255 255 0
numsiginfo 0 36 1024 1024 0
tcpsndbuf 4589416 4589416 9223372036854775807 9223372036854775807 0
tcprcvbuf 786432 802816 9223372036854775807 9223372036854775807 0
othersockbuf 312880 386904 9223372036854775807 9223372036854775807 0
dgramrcvbuf 0 9248 9223372036854775807 9223372036854775807 0
numothersock 331 336 9223372036854775807 9223372036854775807 0
dcachesize 83076802 83199710 9223372036854775807 9223372036854775807 0
numfile 19575 19770 9223372036854775807 9223372036854775807 0
numiptent 102 102 9223372036854775807 9223372036854775807 0
