Hey,
to use Citrix Xen with CM (=Cloudmin), you need to first install XenServer, then create a first VM and install CM in it.
so when you download the CM’s images, you actually download then inside the VM.
when trying to create a new VM, the image used, needs to be transferred into the XS Host otherwise it cannot be used - this process take several minutes.
actually, even when resetting a VM to the same image its being transferred…
is there a better way to do this, to prevent the image transfer with each new VM?
