Changing web root in templete not workin?
Hey there! Just follow the instructions and changed the template “Website for domain” section. Set the DocumentRoot to ${HOME}/public and <Directory ${HOME}/public>. Then created a new Virtual Server and the directory is the same old public_htlml instead of the new “public”.
Any ideas?
@juan.borras If you use Virtualmin with Apache you should also change public_html entry in the template above to public, e.g.:
I personally find this a bit confusing and redundant. @Jamie, should we just update the textbox with Apache template automatically when changing html_dir option in Virtualmin templates page? It isn’t hard to do.
Maybe we should instead just change the “Website subdirectory to create” field to have an “Automatic” option which gets it from the Apache config template?
Hey! Thanks! I missed the “User’s website subdir to create” option!
Sorry!!
Yeah it’s easier, and it could work just great too! I thought to keep it consistent with Nginx at first.
Same the problem is here with me.
did you read
and the bit the OP missed
That fixes it
yes! the choice of webserver used is secondary
@Jamie, where we at about this?
It’s on my TODO list!
Ok in the next release, there will be no danger of a mismatch because the “Users’ website subdirectory to create” will take precedence over the Apache directives template.
