Hi guys
I am running virtualmin and are looking into changing ISP.
That means I get a new external IP address. Do I need to change that in my virtualmin installation and is there one place I can change it for everything?
My local address is still going to be the same som I am only changing the external IP address.
When my IP changes, Virtualmin detects the change and shows a warning / alert message on the Dashboard. In that message is a button to automatically apply the new IP address. I think this is the simplest and easiest way to bring about the change across the system.
Virtualmin + Webmin GUI too could be used manually change the IP address, if someone want to do it the hard(er) way…
Thanks for your reply. If I check under each virtual server:
Virtualmin > Server configuration > Change IP address
I can see that my external IP address is in that field. Is that the same case with you and is that the number that will be changed when I just change my ip address to another?
Thank you so much
Yes, that is correct. That’s the setting which will change.
I should also mention that this is not the only setting which will be changed, so it may not be enough just to change Virtualmin > Server configuration > Change IP address when the public IP address of a server changes.
