It’s possible to change the default php CLI only for one virtual host ?
Yes, this is possible by using the following command:
update-alternatives --config php
Note that this command will set default PHP version for the system and not for a specific user or a virtual server.
I typed the command but nothing happened.
For RHEL systems the command is:
Although, you may need to manually create a new alternatives first.
Also, for a specific virtual server you should just use the full path to the PHP version executable explicitly or create a symlink (as a user) to the PHP version executable you want to be default in user ~/.local/bin directory (which should be always on the path).
