OS: Ubuntu Linux 20.04.2, Webmin: 1.973, Virtualmin: 6.16, Usermin: 1.823, Authentic Theme: 19.73
I wanted to change the Apache ports from 80 and 443 to 82 and 445.
I made the necessary changes in ports.conf
as well as in 000-default.conf
and default-ssl.conf
and netstat
shows that apache is listening to the new ports now:
tcp6 0 0 :::82 :::* LISTEN 74671/apache2
tcp6 0 0 :::445 :::* LISTEN 74671/apache2
In Virtualmin, I did the following two things:
Change the ports for the default virtual server (currently have only this virtual server btw) by going to
Server Configuration > Change IP Adress
and added the new ports there. Now Current web ports show82 (HTTP) 445 (HTTPS)
Change the default ports in
System Settings > Server Templates > Default Settings
to 82 and 443.
Both apache and webmin were restarted after all the changes above were made.
Now when I try to open example.com:82
(domain of the virtual server), I get a “This site can’t be reached” error.
What am I doing wrong and how do I fix this?
