After creating a virtual serveur in Virtualmin, the site is seen on the web.
But after moving the directory via Change Domain Name outside of /home, the site gives a 404 Not Found error.
Yes thank you Joe, but in this case, I need to increase through an NFS folder the limited space I have in /home.
Then I wonder why VirtualMin has a possibility to move if it is not allowed.
It has nothing to do with Nginx, as mount --bind is the kernel feature, and always available. Besides, you could always use bindfs or nullfs (on FreeBSD) to creates a view.
I am very sorry, I am kind of lost.
After moving a working well VM (using NFS) to a new Proxmox server, on the transferred VM everything crazy. Using rsync from a folder to another made the original folder empty and the receiving one as well. The data disappeared. Couldn’t use the mail or the website that is located on the NFS space.
I noticed in Webmin, that the Bind server is not active. Can it be the reason of the issues.
