hi there
i have a issue with changing a domain name. eg x-y-z.com to xyz.com.
i have a full running website, now i have to change the name because of the clients need. i would like to not migrate and setup everything from scratch, hence using the rename domain option in virtualmin.
after rename i end up with:
Not Found
The requested URL / was not found on this server.
Apache/2.2.16 (Debian) Server at xyz.com Port 80
i changed my host-file to directly point to the server leaving out dns-server, which might be not up-to-date.
update:
i had a subdomain running which was not yet changed, therefor apache failed to reload because of ssl certificate not found.
now so far everything is working. i have unfortunately still two main users, the old one i can not delete because virtualmin tells me this will delete 500 mb of data, which is actually the size of the public home, which i do not risk to loose. is this possible? well i could try with a backup, but i rather would like to hear a second opinion, if possible.
any help really appreciated.
best
marc
