Change defaults for all new NGinx sites, e.g. add 'client_max_body_size 30M;'
I’m deploying many new sites on Virtualmin, but I would like to edit the “master” NGinx template to add certain values on each new deploy.
Is this possible?
You go to /etc/nginx/nginx.conf and insert the value you want to.
This is a global setting.
Yannis
Thank you so much @Yannis, I did find an UI way as well.
System Settings->Features and Plugins->NgInx website->Configure button then Additional Nginx directives for new virtual hosts
I’m currently experimenting with both to see which one will work best for our administration workflow.
UPDATE:
Adding the global settings as Additional directives only seems to work for one line items. Our configuration we need the following:
location / { try_files $uri $uri/ /index.php?$query_string; }
This is for WordPress, and we need it per site. When we restore, this restored:
location / { }
An empty location line. I’ll do further experimentation and provide feedback.
