I have installed phpMyAdmin using Virtualmin scripts and after installation all sites which were using CGI/FCGI stopped to execute php. I found that topic which is similar to my issue https://www.virtualmin.com/node/25521 but any solution suggested in it is not working for me.
Thanks for any tips
After update apache packages, I have got same problem.
I don’t know why mod_apache was uninstalled. I install it manually after that CGI/FCGI stopped to execute php. Now only “apache mod_php” works
Eric
September 18, 2015, 3:02pm
3
Which distribution/version are you guys using?
Virtualmin version 4.18.gpl
Webmin version 1.760
Debian Linux 7
Linux 3.2.0-4-amd64 on x86_64
CentOS Linux 6.7 Linux 2.6.32-573.3.1.el6.x86_64 on x86_64
Eric
September 18, 2015, 4:14pm
6
Okay, and what is the output of this command:
rpm -qa | grep php
php-pdo-5.4.45-51.el6.art.x86_64
php-odbc-5.4.45-51.el6.art.x86_64
php-imap-5.4.45-51.el6.art.x86_64
wbm-php-pear-1.5-1.noarch
php-common-5.4.45-51.el6.art.x86_64
php-cli-5.4.45-51.el6.art.x86_64
php-gd-5.4.45-51.el6.art.x86_64
php-snmp-5.4.45-51.el6.art.x86_64
php-xml-5.4.45-51.el6.art.x86_64
php-pear-1.9.4-4.el6.noarch
php-5.4.45-51.el6.art.x86_64
php-mcrypt-5.4.45-51.el6.art.x86_64
php-mbstring-5.4.45-51.el6.art.x86_64
php-mysql-5.4.45-51.el6.art.x86_64
php-pgsql-5.4.45-51.el6.art.x86_64
php-xmlrpc-5.4.45-51.el6.art.x86_64
Eric
September 18, 2015, 6:07pm
8
Ah, yeah, it does look like you’re using a third party repository there, which is likely the cause of the problem.
Just to verify, you’re saying you reviewed this particular solution here:
https://www.virtualmin.com/documentation/system/faq#Why_does_PHP_ProFTPd_no_longer_work_after_performing_updates_I-m_using_CentOS_and_enabled_third_party_repositories
OK. I have downgraded PHP from 5.4 (Atomic) to 5.3 (EPEL) but still have same problem to run PHP as CGI/FCGI
Well - /etc/httpd/conf.d/php.conf had added AddHandler not SetHandler - commented out that line and now I can run PHP as CGI/FCGI
Eric
September 18, 2015, 7:06pm
11
Great, I’m glad to hear you got it working now!
Same problem with Debian 7 x64
libapache2-mod-php5 5.4.45-0+deb7u1
php-pear 5.4.45-0+deb7u1
php5-cgi 5.4.45-0+deb7u1
php5-cli 5.4.45-0+deb7u1
php5-common 5.4.45-0+deb7u1
php5-curl 5.4.45-0+deb7u1
php5-gd 5.4.45-0+deb7u1
php5-geoip 1.0.7-8
php5-imagick 3.1.0~rc1-1+b2
php5-mcrypt 5.4.45-0+deb7u1
php5-mysql 5.4.45-0+deb7u1
My sources.list
deb http://ftp.nl.debian.org/debian/ wheezy main
deb-src http://ftp.nl.debian.org/debian/ wheezy main
deb http://security.debian.org/ wheezy/updates main
deb-src http://security.debian.org/ wheezy/updates main
wheezy-updates, previously known as ‘volatile’
deb http://ftp.nl.debian.org/debian/ wheezy-updates main
deb-src http://ftp.nl.debian.org/debian/ wheezy-updates main
deb http://software.virtualmin.com/gpl/debian/ virtualmin-wheezy main
deb http://software.virtualmin.com/gpl/debian/ virtualmin-universal main
