Good Evening,
i have a problem with my Postfix mail server on the Virtualmin server. I’ve been trying for a long time to figure out why I can’t send via SSL.
Initial situation:
I have several domains. Each domain has its own Lets Encrypt certificate and I also provided this for Postfix and Dovecot. However, Postfix always takes the wrong domain when sending SMTP and complains about it because the certificate would be wrong. (e.g. Did I assign a certificate to domain a.xy, but Microsoft Outlook says that the principal name is wrong because the certificate belongs to domain b.xy).
What could be the reason and what details do you need from me ?
main.cf
See /usr/share/postfix/main.cf.dist for a commented, more complete version
Debian specific: Specifying a file name will cause the first
line of that file to be used as the name. The Debian default
is /etc/mailname.
#myorigin = /etc/mailname
sender_canonical_maps = hash:/etc/postfix/sender_canonical
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
appending .domain is the MUA’s job.
append_dot_mydomain = no
Uncomment the next line to generate “delayed mail” warnings
#delay_warning_time = 4h
readme_directory = no
See http://www.postfix.org/COMPATIBILITY_README.html – default to 2 on
fresh installs.
compatibility_level = 2
TLS parameters
smtpd_tls_cert_file = /etc/postfix/postfix.cert.pem
smtpd_tls_key_file = /etc/postfix/postfix.key.pem
smtpd_tls_CAfile = /etc/postfix/postfix.ca.pem
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
information on enabling SSL in the smtp client.
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
myhostname = vmd39417.contaboserver.net
mydestination = $myhostname, vmd39417.contaboserver.net, localhost.contaboserver.net, , localhost
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_protocols = all
home_mailbox = Maildir/
smtpd_sasl_auth_enable = yes
smtp_tls_security_level = dane
allow_percent_hack = no
smtpd_tls_security_level = may
smtpd_tls_mandatory_protocols = !SSLv2, !SSLv3, !TLSv1, !TLSv1.1
mynetworks_style = subnet
mydomain = contaboserver.net
Thanks a lot
