hello all -
i ran into quite a few issues, but i believe i have successfully installed on centos/rh 8
below is a quick overview of what i ran into, including the extra commands required to get the installation to work.
NOTE: i was installing each time on a new google-cloud VPS, to ensure a fresh OS.
PRE-INSTALL:
## you may want to carefully look at SELinux.
setenforce permissive ; ## this should be made permanent in /etc/selinux/config
getenforce ; ### double-check
WEBMIN:
dnf --assumeyes install wget gcc pam-devel ;
dnf module --assumeyes install perl:5.26 ;
dnf install perl-CPAN ;
dnf --assumeyes install perl-open.noarch ;
PERL_MM_USE_DEFAULT=1 cpan -i CPAN ; ## initialize cpan for first run
/usr/bin/cpan -i Authen::PAM ;
https://github.com/webmin/webmin/pull/1218 -- fix setup.sh script
https://github.com/webmin/webmin/pull/1222 -- fix PIDFile /usr/lib/systemd/system/webmin.service
POST-WEBMIN-INSTALL
## interesting situation - webmin is running before systemctl knows about it. I found it best to stop
## webmin manually before proceeding.
kill -9 $(pgrep miniserv; ) ## kill the one started by the installation process
systemctl enable webmin.service ;
systemctl stop webmin.service ; ## just in case....
systemctl start webmin.service ;
systemctl status webmin.service ; ## double check
VIRTUALMIN:
systemctl stop firewalld.service ; ## virtualmin appears to only complete if the firewall is temporarily down
virtuamin: (had to run this several times)
https://github.com/virtualmin/virtualmin-install/pull/31 -- suppress PowerTools for redhat
This installation is still more difficult than it should be, given how easy Centos 6&7 are. But once this matures a bit, hopefully these issues will be resolved.
mesage about running install multiple times:
Virtualmin may already be installed. This can happen if an installation failed,
and can be ignored in that case.
EDIT: i am wondering if the error on the step:
“[20/23] Configuring Webmin” : “Error: Failed to restart Webmin server!”
is because of how webmin is somehow starting internally rather than using systemctl
in other words, when i enter systemctl stop webmin.service
, often times i also have to enter:
and i am wondering if there is a way around this?
note that when i run several times and rely on “luck” to complete the virtualmin install, i get this status message:
PID 13465 from file /var/webmin/miniserv.pid is not valid
This was the same error message i was receiving using systemctl
until i created this PR.
