Guys, does anyone know if Centos 8 could work with other php versions?.. It seems that I can only use 7.2. I tried going into Server Config/php options and there’s no option to choose a different version. The only PHP script execution mode I see is FPM… This is a new installation and several apps won’t work with php 7.2. Please advice. Thanks
But, if you must install other versions, I recommend you do so from a trustworthy source. SCL doesn’t seem to have anything newer than 7.2, but Remi does, and their packages tend to be pretty good.
I am not recommending you install additional PHP versions, but if you must, Remi is competent and probably won’t break much. Make sure you need it first, though. None of the apps I’ve tested have a problem with 7.2.
Highly advise that you move to something like CentOS Stream 8 (as CentOS 8 will be unsupported soon), however you can do something like this to get the official packages (without having to use Remi):
Oh, that’s good. I didn’t know you could grab stream packages without being entirely on Stream.
I wouldn’t recommend switching the OS to Stream just yet. We haven’t done any testing there. But, as a source for newer PHP versions for people that must have them, I think it’s likely a very good option (almost certainly the best option).
