CentOS 7 clean minimal plus perl and wget install
So I have an error code 22 on installing Virtualmin. Current updated CentOS 7 with a minimal install. Added WGET and PERL. Hosted on HYPER-V 2012 R2.
Logged in as ROOT and Virtualmin install fails with error 22.
Any assistance is appreciated. I have had successful installations earlier in the year but not this time.
VIRTUALMIN-INSTALL.LOG
INFO - 2016-12-12 13:54:18 - Started installation log in /root/virtualmin-install.log
DEBUG - 2016-12-12 13:54:18 - Install mode: full
DEBUG - 2016-12-12 13:54:18 - Product: Virtualmin Professional
DEBUG - 2016-12-12 13:54:18 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2016-12-12 13:54:18 - install.sh version: 1.1.5
INFO - 2016-12-12 13:54:18 - Checking for fully qualified hostname…
INFO - 2016-12-12 13:54:18 - Hostname OK: fully qualified as domain.domain.domain
INFO - 2016-12-12 13:54:19 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2016-12-12 13:54:19 - Loading OS selection library…
INFO - 2016-12-12 13:54:19 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2016-12-12 13:54:19 - Loading OS list…
INFO - 2016-12-12 13:54:19 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2016-12-12 13:54:19 - Operating system name: CentOS Linux
INFO - 2016-12-12 13:54:19 - Operating system version: 7.3.1611
INFO - 2016-12-12 13:54:19 - Configuring package manager for CentOS Linux 7.3.1611…
INFO - 2016-12-12 13:54:19 - Disabling SELinux during installation…
DEBUG - 2016-12-12 13:54:19 - setenforce 0 succeeded
INFO - 2016-12-12 13:54:21 - Download of http://license@software.virtualmin.com/rhel/7.3.1611/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
FATAL - 2016-12-12 13:54:21 - Fatal Error Occurred: Installation of virtualmin-release failed: 22
FATAL - 2016-12-12 13:54:21 - Cannot continue installation.
FATAL - 2016-12-12 13:54:21 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2016-12-12 13:54:21 - re-attempted after any problems have been resolved.
FATAL - 2016-12-12 13:54:22 - Removing temporary directory and files.
FATAL - 2016-12-12 13:54:22 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2016-12-12 13:54:22 - in /root/virtualmin-install.log
Should be fixed now. The new CentOS release leads to it searching for a weird named path. We’ve added symbolic links to correct the problem.
