I have read that I have to install a fresh centos system and the gpl automatic script to get the correct httpd version automatically, but it installs an apache version of updates repository.
I have read that apache version of virtualmin repository installs the Suexec command configured to /home
Then if I check the configuration I get this message:
The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin virtual server home directory is /home. CGI and PHP scripts run as domain owners will not be executed.
I have installed a minimal version of CentOS (7.2.1511) - CentOS-7-x86_64-Minimal-1511.iso
I have updated the system
I have downloaded the file gpl installer from:
wget http://software.virtualmin.com/gpl/scripts/install.sh
I have added hostname
I have installed virtualmin
But it doesn’t install the apache version from the virtualmin repository.
httpd.x86_64 – 2.4.6-40.el7.centos.4 – @updates
How can I get the system ready for Virtualmin.
I have read this:
To resolve this you will have to recompile apache with /home as a base directory for mod_suexec module.
I was searching for a solution everywhere but I didn’t found it.
Do you know how can I fix it?
Thank you.
