After installing Webmin then Virtualmin and having some issues I decided to start with a fresh install of CentOS 5 64bit and try using install.sh script.
Everything seemed to be going well but installation ran into some issues. I’ve posted the output log.
INFO - 2011-04-06 19:18:09 - Started installation log in /root/virtualmin-install.log DEBUG - 2011-04-06 19:18:10 - Install mode: full DEBUG - 2011-04-06 19:18:10 - Product: Virtualmin GPL DEBUG - 2011-04-06 19:18:10 - Virtualmin Meta-Package list: virtualmin-base DEBUG - 2011-04-06 19:18:10 - install.sh version: 1.0.5 INFO - 2011-04-06 19:18:10 - Checking for fully qualified hostname... INFO - 2011-04-06 19:18:10 - Hostname OK: fully qualified as s1.dhonki.com INFO - 2011-04-06 19:18:11 - Installing serial number and license key into /etc/virtualmin-license INFO - 2011-04-06 19:18:11 - Loading OS selection library... INFO - 2011-04-06 19:18:17 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded. INFO - 2011-04-06 19:18:18 - Loading OS list... INFO - 2011-04-06 19:18:23 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded. INFO - 2011-04-06 19:18:23 - Operating system name: CentOS Linux INFO - 2011-04-06 19:18:23 - Operating system version: 5 INFO - 2011-04-06 19:18:23 - Configuring package manager for CentOS Linux 5... INFO - 2011-04-06 19:18:24 - Disabling SELinux during installation... INFO - 2011-04-06 19:18:24 - setenforce 0 failed: 1 INFO - 2011-04-06 19:18:29 - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded. INFO - 2011-04-06 19:18:31 - Succeeded. INFO - 2011-04-06 19:18:32 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay Loaded plugins: fastestmirror Loading mirror speeds from cached hostfile * addons: mirrors.cmich.edu * base: mirror.raystedman.net * extras: pubmirrors.reflected.net * updates: mirror.ubiquityservers.com Setting up Install Process Package 30:bind-9.3.6-4.P1.el5_5.3.x86_64 already installed and latest version Package 30:bind-utils-9.3.6-4.P1.el5_5.3.x86_64 already installed and latest version Package 30:caching-nameserver-9.3.6-4.P1.el5_5.3.x86_64 already installed and latest version Package 30:bind-9.3.6-4.P1.el5_5.3.x86_64 already installed and latest version Package procmail-3.22-17.1.el5.centos.x86_64 already installed and latest version Package 1:quota-3.13-1.2.5.el5.x86_64 already installed and latest version Package iptables-1.3.5-5.3.el5_4.1.x86_64 already installed and latest version Package openssl-0.9.8e-12.el5_5.7.x86_64 already installed and latest version Package openssl-0.9.8e-12.el5_5.7.i686 already installed and latest version Package python-2.4.3-27.el5_5.3.x86_64 already installed and latest version No package rh-postgresql available. No package rh-postgresql-server available. Package logrotate-3.7.4-9.el5_5.2.x86_64 already installed and latest version No package php-domxl available. Package cyrus-sasl-2.1.22-5.el5_4.3.x86_64 already installed and latest version Resolving Dependencies --> Running transaction check ---> Package cyrus-sasl.i386 0:2.1.22-5.el5_4.3 set to be updated --> Processing Dependency: libpam.so.0(LIBPAM_1.0) for package: cyrus-sasl --> Processing Dependency: libsasl2.so.2 for package: cyrus-sasl --> Processing Dependency: libldap-2.3.so.0 for package: cyrus-sasl --> Processing Dependency: libgdbm.so.2 for package: cyrus-sasl --> Processing Dependency: libpam.so.0 for package: cyrus-sasl --> Processing Dependency: liblber-2.3.so.0 for package: cyrus-sasl ---> Package cyrus-sasl-gssapi.i386 0:2.1.22-5.el5_4.3 set to be updated ---> Package cyrus-sasl-gssapi.x86_64 0:2.1.22-5.el5_4.3 set to be updated ---> Package dovecot.x86_64 0:1.0.7-7.el5 set to be updated ---> Package httpd.x86_64 1:2.2.3-43.3.vm set to be updated ---> Package mailman.x86_64 3:2.1.9-4.el5 set to be updated ---> Package mod_dav_svn.x86_64 0:1.4.2-4.el5_3.1 set to be updated ---> Package mod_perl.x86_64 0:2.0.4-6.el5 set to be updated --> Processing Dependency: perl(BSD::Resource) for package: mod_perl ---> Package mod_python.x86_64 0:3.2.8-3.1 set to be updated ---> Package mod_ssl.x86_64 2:2.2.3-43.3.vm set to be updated --> Processing Dependency: libdistcache.so.1()(64bit) for package: mod_ssl --> Processing Dependency: libnal.so.1()(64bit) for package: mod_ssl ---> Package mysql.i386 0:5.0.77-4.el5_5.4 set to be updated --> Processing Dependency: perl(DBI) for package: mysql ---> Package mysql.x86_64 0:5.0.77-4.el5_5.4 set to be updated ---> Package mysql-devel.i386 0:5.0.77-4.el5_5.4 set to be updated --> Processing Dependency: openssl-devel for package: mysql-devel ---> Package mysql-devel.x86_64 0:5.0.77-4.el5_5.4 set to be updated ---> Package mysql-server.x86_64 0:5.0.77-4.el5_5.4 set to be updated ---> Package perl-Crypt-SSLeay.x86_64 0:0.51-11.el5 set to be updated ---> Package perl-DBD-MySQL.x86_64 0:3.0007-2.el5 set to be updated ---> Package perl-DBD-Pg.x86_64 0:1.49-2.el5_3.1 set to be updated ---> Package perl-XML-Simple.noarch 0:2.14-4.fc6 set to be updated --> Processing Dependency: perl(XML::Parser) for package: perl-XML-Simple ---> Package php.x86_64 0:5.1.6-27.el5_5.3 set to be updated --> Processing Dependency: php-common = 5.1.6-27.el5_5.3 for package: php --> Processing Dependency: php-cli = 5.1.6-27.el5_5.3 for package: php --> Processing Dependency: libgmp.so.3()(64bit) for package: php ---> Package php-gd.x86_64 0:5.1.6-27.el5_5.3 set to be updated --> Processing Dependency: libfreetype.so.6()(64bit) for package: php-gd ---> Package php-imap.x86_64 0:5.1.6-27.el5_5.3 set to be updated --> Processing Dependency: libc-client.so.1()(64bit) for package: php-imap ---> Package php-mbstring.x86_64 0:5.1.6-27.el5_5.3 set to be updated ---> Package php-mysql.x86_64 0:5.1.6-27.el5_5.3 set to be updated --> Processing Dependency: php-pdo for package: php-mysql ---> Package php-odbc.x86_64 0:5.1.6-27.el5_5.3 set to be updated --> Processing Dependency: libodbc.so.1()(64bit) for package: php-odbc ---> Package php-pear.noarch 1:1.4.9-6.el5 set to be updated --> Processing Dependency: php-devel for package: php-pear ---> Package php-pgsql.x86_64 0:5.1.6-27.el5_5.3 set to be updated ---> Package php-snmp.x86_64 0:5.1.6-27.el5_5.3 set to be updated ---> Package php-xmlrpc.x86_64 0:5.1.6-27.el5_5.3 set to be updated ---> Package postfix.x86_64 2:2.3.3-2.1.el5_2 set to be updated ---> Package postgresql.x86_64 0:8.1.22-1.el5_5.1 set to be updated ---> Package postgresql-server.x86_64 0:8.1.22-1.el5_5.1 set to be updated ---> Package ruby.x86_64 0:1.8.5-5.el5_4.8 set to be updated --> Processing Dependency: ruby-libs = 1.8.5-5.el5_4.8 for package: ruby --> Processing Dependency: libruby.so.1.8()(64bit) for package: ruby ---> Package ruby-devel.i386 0:1.8.5-5.el5_4.8 set to be updated --> Processing Dependency: libruby.so.1.8 for package: ruby-devel ---> Package ruby-devel.x86_64 0:1.8.5-5.el5_4.8 set to be updated ---> Package rubygems.noarch 0:0.9.2-1.el5 set to be updated --> Processing Dependency: ruby-rdoc for package: rubygems ---> Package spamassassin.x86_64 0:3.2.5-1.el5 set to be updated --> Processing Dependency: perl(IO::Zlib) >= 1.04 for package: spamassassin --> Processing Dependency: perl-HTML-Parser >= 3.43 for package: spamassassin --> Processing Dependency: perl(HTML::Parser) >= 3.43 for package: spamassassin --> Processing Dependency: perl(Archive::Tar) >= 1.23 for package: spamassassin --> Processing Dependency: perl(HTTP::Date) for package: spamassassin --> Processing Dependency: perl(IO::Socket::INET6) for package: spamassassin --> Processing Dependency: perl(LWP::UserAgent) for package: spamassassin --> Processing Dependency: perl(IO::Socket::SSL) for package: spamassassin --> Processing Dependency: perl(Net::DNS) for package: spamassassin --> Processing Dependency: perl(Archive::Tar) for package: spamassassin --> Processing Dependency: perl(Digest::SHA1) for package: spamassassin ---> Package subversion.i386 0:1.4.2-4.el5_3.1 set to be updated --> Processing Dependency: perl(URI) >= 1.17 for package: subversion --> Processing Dependency: neon >= 0.25.5-6.el5 for package: subversion --> Processing Dependency: libneon.so.25 for package: subversion --> Processing Dependency: libapr-1.so.0 for package: subversion --> Processing Dependency: libaprutil-1.so.0 for package: subversion --> Processing Dependency: libdb-4.3.so for package: subversion --> Processing Dependency: libexpat.so.0 for package: subversion ---> Package subversion.x86_64 0:1.4.2-4.el5_3.1 set to be updated ---> Package webalizer.x86_64 0:2.01_10-30.1 set to be updated --> Processing Dependency: libgd.so.2()(64bit) for package: webalizer --> Running transaction check ---> Package apr.i386 0:1.2.7-11.el5_5.3 set to be updated ---> Package apr-util.i386 0:1.2.7-11.el5_5.2 set to be updated --> Processing Dependency: libsqlite3.so.0 for package: apr-util --> Processing Dependency: libpq.so.4 for package: apr-util ---> Package cyrus-sasl-lib.i386 0:2.1.22-5.el5_4.3 set to be updated ---> Package db4.i386 0:4.3.29-10.el5_5.2 set to be updated ---> Package distcache.x86_64 0:1.4.5-14.1 set to be updated ---> Package expat.i386 0:1.95.8-8.3.el5_5.3 set to be updated ---> Package freetype.x86_64 0:2.2.1-28.el5_5.1 set to be updated ---> Package gd.x86_64 0:2.0.33-9.4.el5_4.2 set to be updated --> Processing Dependency: pkgconfig for package: gd --> Processing Dependency: libXpm.so.4()(64bit) for package: gd --> Processing Dependency: libfontconfig.so.1()(64bit) for package: gd --> Processing Dependency: libX11.so.6()(64bit) for package: gd ---> Package gdbm.i386 0:1.8.0-26.2.1 set to be updated ---> Package gmp.x86_64 0:4.1.4-10.el5 set to be updated ---> Package libc-client.x86_64 0:2004g-2.2.1 set to be updated ---> Package neon.i386 0:0.25.5-10.el5_4.1 set to be updated ---> Package neon.x86_64 0:0.25.5-10.el5_4.1 set to be updated ---> Package openldap.i386 0:2.3.43-12.el5_5.3 set to be updated ---> Package openssl-devel.x86_64 0:0.9.8e-12.el5_5.7 set to be updated --> Processing Dependency: zlib-devel for package: openssl-devel --> Processing Dependency: krb5-devel for package: openssl-devel ---> Package pam.i386 0:0.99.6.2-6.el5_5.2 set to be updated --> Processing Dependency: libcrack.so.2 for package: pam --> Processing Dependency: libaudit.so.0 for package: pam ---> Package perl-Archive-Tar.noarch 1:1.39.1-1.el5_5.2 set to be updated --> Processing Dependency: perl(Compress::Zlib) for package: perl-Archive-Tar ---> Package perl-BSD-Resource.x86_64 0:1.28-1.fc6.1 set to be updated ---> Package perl-DBI.x86_64 0:1.52-2.el5 set to be updated ---> Package perl-Digest-SHA1.x86_64 0:2.11-1.2.1 set to be updated ---> Package perl-HTML-Parser.x86_64 0:3.55-1.fc6 set to be updated --> Processing Dependency: perl-HTML-Tagset >= 3.03 for package: perl-HTML-Parser --> Processing Dependency: perl(HTML::Tagset) for package: perl-HTML-Parser ---> Package perl-IO-Socket-INET6.noarch 0:2.51-2.fc6 set to be updated --> Processing Dependency: perl(Socket6) for package: perl-IO-Socket-INET6 ---> Package perl-IO-Socket-SSL.noarch 0:1.01-1.fc6 set to be updated --> Processing Dependency: perl(Net::SSLeay) >= 1.21 for package: perl-IO-Socket-SSL ---> Package perl-IO-Zlib.noarch 0:1.04-4.2.1 set to be updated ---> Package perl-Net-DNS.x86_64 0:0.59-3.el5 set to be updated --> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-DNS --> Processing Dependency: perl(Net::IP) for package: perl-Net-DNS ---> Package perl-URI.noarch 0:1.35-3 set to be updated ---> Package perl-XML-Parser.x86_64 0:2.34-6.1.2.2.1 set to be updated ---> Package perl-libwww-perl.noarch 0:5.805-1.1.1 set to be updated ---> Package php-cli.x86_64 0:5.1.6-27.el5_5.3 set to be updated ---> Package php-common.x86_64 0:5.1.6-27.el5_5.3 set to be updated ---> Package php-devel.x86_64 0:5.1.6-27.el5_5.3 set to be updated --> Processing Dependency: autoconf for package: php-devel --> Processing Dependency: automake for package: php-devel ---> Package php-pdo.x86_64 0:5.1.6-27.el5_5.3 set to be updated ---> Package ruby-libs.i386 0:1.8.5-5.el5_4.8 set to be updated --> Processing Dependency: libtermcap.so.2 for package: ruby-libs --> Processing Dependency: libreadline.so.5 for package: ruby-libs ---> Package ruby-libs.x86_64 0:1.8.5-5.el5_4.8 set to be updated ---> Package ruby-rdoc.x86_64 0:1.8.5-5.el5_4.8 set to be updated --> Processing Dependency: ruby-irb = 1.8.5-5.el5_4.8 for package: ruby-rdoc ---> Package unixODBC.x86_64 0:2.2.11-7.1 set to be updated --> Running transaction check ---> Package audit-libs.i386 0:1.7.17-3.el5 set to be updated ---> Package autoconf.noarch 0:2.59-12 set to be updated --> Processing Dependency: imake for package: autoconf ---> Package automake.noarch 0:1.9.6-2.3.el5 set to be updated ---> Package cracklib.i386 0:2.8.9-3.3 set to be updated ---> Package fontconfig.x86_64 0:2.4.1-7.el5 set to be updated ---> Package krb5-devel.x86_64 0:1.6.1-36.el5_5.6 set to be updated --> Processing Dependency: libselinux-devel for package: krb5-devel --> Processing Dependency: e2fsprogs-devel for package: krb5-devel --> Processing Dependency: keyutils-libs-devel for package: krb5-devel ---> Package libX11.x86_64 0:1.0.3-11.el5 set to be updated --> Processing Dependency: xorg-x11-filesystem >= 0.99.2-3 for package: libX11 --> Processing Dependency: libXdmcp.so.6()(64bit) for package: libX11 --> Processing Dependency: libXau.so.6()(64bit) for package: libX11 ---> Package libXpm.x86_64 0:3.5.5-3 set to be updated ---> Package libtermcap.i386 0:2.0.8-46.1 set to be updated ---> Package perl-Compress-Zlib.x86_64 0:1.42-1.fc6 set to be updated ---> Package perl-Digest-HMAC.noarch 0:1.01-15 set to be updated ---> Package perl-HTML-Tagset.noarch 0:3.10-2.1.1 set to be updated ---> Package perl-Net-IP.noarch 0:1.25-2.fc6 set to be updated ---> Package perl-Net-SSLeay.x86_64 0:1.30-4.fc6 set to be updated ---> Package perl-Socket6.x86_64 0:0.19-3.fc6 set to be updated ---> Package pkgconfig.x86_64 1:0.21-2.el5 set to be updated ---> Package postgresql-libs.i386 0:8.1.22-1.el5_5.1 set to be updated ---> Package readline.i386 0:5.1-3.el5 set to be updated ---> Package ruby-irb.x86_64 0:1.8.5-5.el5_4.8 set to be updated ---> Package sqlite.i386 0:3.3.6-5 set to be updated ---> Package zlib-devel.x86_64 0:1.2.3-3 set to be updated --> Running transaction check ---> Package e2fsprogs-devel.x86_64 0:1.39-23.el5_5.1 set to be updated ---> Package imake.x86_64 0:1.0.2-3 set to be updated ---> Package keyutils-libs-devel.x86_64 0:1.2-1.el5 set to be updated ---> Package libXau.x86_64 0:1.0.1-3.1 set to be updated ---> Package libXdmcp.x86_64 0:1.0.1-2.1 set to be updated ---> Package libselinux-devel.x86_64 0:1.33.4-5.5.el5 set to be updated --> Processing Dependency: libsepol-devel >= 1.15.2-1 for package: libselinux-devel ---> Package xorg-x11-filesystem.noarch 0:7.1-2.fc6 set to be updated --> Running transaction check ---> Package libsepol-devel.x86_64 0:1.15.2-3.el5 set to be updated --> Finished Dependency Resolution Dependencies Resolved ================================================================================ Package Arch Version Repository Size ================================================================================ Installing: cyrus-sasl i386 2.1.22-5.el5_4.3 base 1.2 M cyrus-sasl-gssapi i386 2.1.22-5.el5_4.3 base 29 k cyrus-sasl-gssapi x86_64 2.1.22-5.el5_4.3 base 30 k dovecot x86_64 1.0.7-7.el5 base 1.7 M mailman x86_64 3:2.1.9-4.el5 base 9.8 M mod_dav_svn x86_64 1.4.2-4.el5_3.1 base 70 k mod_perl x86_64 2.0.4-6.el5 base 4.0 M mod_python x86_64 3.2.8-3.1 base 260 k mod_ssl x86_64 2:2.2.3-43.3.vm virtualmin 92 k mysql i386 5.0.77-4.el5_5.4 updates 4.8 M mysql x86_64 5.0.77-4.el5_5.4 updates 4.8 M mysql-devel i386 5.0.77-4.el5_5.4 updates 2.4 M mysql-devel x86_64 5.0.77-4.el5_5.4 updates 2.5 M mysql-server x86_64 5.0.77-4.el5_5.4 updates 9.8 M perl-Crypt-SSLeay x86_64 0.51-11.el5 base 45 k perl-DBD-MySQL x86_64 3.0007-2.el5 base 148 k perl-DBD-Pg x86_64 1.49-2.el5_3.1 base 115 k perl-XML-Simple noarch 2.14-4.fc6 base 68 k php x86_64 5.1.6-27.el5_5.3 updates 2.3 M php-gd x86_64 5.1.6-27.el5_5.3 updates 118 k php-imap x86_64 5.1.6-27.el5_5.3 updates 55 k php-mbstring x86_64 5.1.6-27.el5_5.3 updates 1.0 M php-mysql x86_64 5.1.6-27.el5_5.3 updates 89 k php-odbc x86_64 5.1.6-27.el5_5.3 updates 54 k php-pear noarch 1:1.4.9-6.el5 base 344 k php-pgsql x86_64 5.1.6-27.el5_5.3 updates 70 k php-snmp x86_64 5.1.6-27.el5_5.3 updates 30 k php-xmlrpc x86_64 5.1.6-27.el5_5.3 updates 57 k postfix x86_64 2:2.3.3-2.1.el5_2 base 3.7 M postgresql x86_64 8.1.22-1.el5_5.1 updates 2.9 M postgresql-server x86_64 8.1.22-1.el5_5.1 updates 3.9 M ruby x86_64 1.8.5-5.el5_4.8 base 274 k ruby-devel i386 1.8.5-5.el5_4.8 base 556 k ruby-devel x86_64 1.8.5-5.el5_4.8 base 564 k rubygems noarch 0.9.2-1.el5 virtualmin 497 k spamassassin x86_64 3.2.5-1.el5 base 1.0 M subversion i386 1.4.2-4.el5_3.1 base 2.3 M subversion x86_64 1.4.2-4.el5_3.1 base 2.4 M webalizer x86_64 2.01_10-30.1 base 112 k Updating: httpd x86_64 1:2.2.3-43.3.vm virtualmin 1.2 M Installing for dependencies: apr i386 1.2.7-11.el5_5.3 updates 123 k apr-util i386 1.2.7-11.el5_5.2 updates 80 k audit-libs i386 1.7.17-3.el5 base 78 k autoconf noarch 2.59-12 base 647 k automake noarch 1.9.6-2.3.el5 base 476 k cracklib i386 2.8.9-3.3 base 58 k cyrus-sasl-lib i386 2.1.22-5.el5_4.3 base 127 k db4 i386 4.3.29-10.el5_5.2 updates 910 k distcache x86_64 1.4.5-14.1 base 121 k e2fsprogs-devel x86_64 1.39-23.el5_5.1 updates 633 k expat i386 1.95.8-8.3.el5_5.3 updates 77 k fontconfig x86_64 2.4.1-7.el5 base 175 k freetype x86_64 2.2.1-28.el5_5.1 updates 311 k gd x86_64 2.0.33-9.4.el5_4.2 base 155 k gdbm i386 1.8.0-26.2.1 base 27 k gmp x86_64 4.1.4-10.el5 base 201 k imake x86_64 1.0.2-3 base 319 k keyutils-libs-devel x86_64 1.2-1.el5 base 27 k krb5-devel x86_64 1.6.1-36.el5_5.6 updates 1.9 M libX11 x86_64 1.0.3-11.el5 base 798 k libXau x86_64 1.0.1-3.1 base 18 k libXdmcp x86_64 1.0.1-2.1 base 19 k libXpm x86_64 3.5.5-3 base 44 k libc-client x86_64 2004g-2.2.1 base 515 k libselinux-devel x86_64 1.33.4-5.5.el5 base 149 k libsepol-devel x86_64 1.15.2-3.el5 base 192 k libtermcap i386 2.0.8-46.1 base 14 k neon i386 0.25.5-10.el5_4.1 base 101 k neon x86_64 0.25.5-10.el5_4.1 base 100 k openldap i386 2.3.43-12.el5_5.3 updates 295 k openssl-devel x86_64 0.9.8e-12.el5_5.7 updates 1.9 M pam i386 0.99.6.2-6.el5_5.2 updates 980 k perl-Archive-Tar noarch 1:1.39.1-1.el5_5.2 updates 53 k perl-BSD-Resource x86_64 1.28-1.fc6.1 base 29 k perl-Compress-Zlib x86_64 1.42-1.fc6 base 52 k perl-DBI x86_64 1.52-2.el5 base 600 k perl-Digest-HMAC noarch 1.01-15 base 12 k perl-Digest-SHA1 x86_64 2.11-1.2.1 base 49 k perl-HTML-Parser x86_64 3.55-1.fc6 base 92 k perl-HTML-Tagset noarch 3.10-2.1.1 base 15 k perl-IO-Socket-INET6 noarch 2.51-2.fc6 base 13 k perl-IO-Socket-SSL noarch 1.01-1.fc6 base 49 k perl-IO-Zlib noarch 1.04-4.2.1 base 15 k perl-Net-DNS x86_64 0.59-3.el5 base 215 k perl-Net-IP noarch 1.25-2.fc6 base 31 k perl-Net-SSLeay x86_64 1.30-4.fc6 base 192 k perl-Socket6 x86_64 0.19-3.fc6 base 21 k perl-URI noarch 1.35-3 base 116 k perl-XML-Parser x86_64 2.34-6.1.2.2.1 base 210 k perl-libwww-perl noarch 5.805-1.1.1 base 376 k php-cli x86_64 5.1.6-27.el5_5.3 updates 2.2 M php-common x86_64 5.1.6-27.el5_5.3 updates 153 k php-devel x86_64 5.1.6-27.el5_5.3 updates 503 k php-pdo x86_64 5.1.6-27.el5_5.3 updates 66 k pkgconfig x86_64 1:0.21-2.el5 base 61 k postgresql-libs i386 8.1.22-1.el5_5.1 updates 196 k readline i386 5.1-3.el5 base 223 k ruby-irb x86_64 1.8.5-5.el5_4.8 base 69 k ruby-libs i386 1.8.5-5.el5_4.8 base 1.6 M ruby-libs x86_64 1.8.5-5.el5_4.8 base 1.6 M ruby-rdoc x86_64 1.8.5-5.el5_4.8 base 134 k sqlite i386 3.3.6-5 base 213 k unixODBC x86_64 2.2.11-7.1 base 835 k xorg-x11-filesystem noarch 7.1-2.fc6 base 5.4 k zlib-devel x86_64 1.2.3-3 base 102 k Transaction Summary ================================================================================ Install 104 Package(s) Upgrade 1 Package(s) Total download size: 87 M Downloading Packages: -------------------------------------------------------------------------------- Total 476 kB/s | 87 MB 03:06 Running rpm_check_debug Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing : php-common 1/106 Updating : httpd 2/106 Installing : perl-DBI 3/106 Installing : mysql 4/106 Installing : php-pdo 5/106 Installing : freetype 6/106 Installing : perl-Compress-Zlib 7/106 Installing : perl-Digest-SHA1 8/106 Installing : gmp 9/106 Installing : php-cli 10/106 Installing : ruby-libs 11/106 Installing : neon 12/106 Installing : cyrus-sasl-lib 13/106 Installing : openldap 14/106 Installing : mysql 15/106 Installing : expat 16/106 Installing : db4 17/106 Installing : readline 18/106 Installing : gdbm 19/106 Installing : postgresql-libs 20/106 Installing : apr 21/106 Installing : php 22/106 Installing : fontconfig 23/106 Installing : perl-DBD-MySQL 24/106 Installing : distcache 25/106 Installing : libXau 26/106 Installing : perl-Net-SSLeay 27/106 Installing : pkgconfig 28/106 Installing : perl-Socket6 29/106 Installing : imake 30/106 Installing : postgresql 31/106 Installing : libXdmcp 32/106 Installing : unixODBC 33/106 Installing : perl-BSD-Resource 34/106 Installing : perl-URI 35/106 Installing : autoconf 36/106 Installing : perl-IO-Zlib 37/106 Installing : subversion 38/106 Installing : perl-Archive-Tar 39/106 Installing : automake 40/106 Installing : php-devel 41/106 Installing : perl-IO-Socket-INET6 42/106 Installing : perl-IO-Socket-SSL 43/106 Installing : perl-Digest-HMAC 44/106 Installing : perl-Net-IP 45/106 Installing : perl-Net-DNS 46/106 Installing : zlib-devel 47/106 Installing : xorg-x11-filesystem 48/106 Installing : libX11 49/106 Installing : libXpm 50/106 Installing : gd 51/106 Installing : e2fsprogs-devel 52/106 Installing : keyutils-libs-devel 53/106 Installing : libsepol-devel 54/106 Installing : libselinux-devel 55/106 Installing : krb5-devel 56/106 Installing : openssl-devel 57/106 Installing : perl-HTML-Tagset 58/106 Installing : perl-HTML-Parser 59/106 Installing : sqlite 60/106 Installing : apr-util 61/106 Installing : neon 62/106 Installing : subversion 63/106 Installing : audit-libs 64/106 Installing : libtermcap 65/106 Installing : ruby-libs 66/106 Installing : ruby 67/106 Installing : cracklib 68/106 Installing : mod_dav_svn 69/106 Installing : webalizer 70/106 Installing : mod_perl 71/106 Installing : php-odbc 72/106 Installing : postgresql-server 73/106 Installing : mod_ssl 74/106 Installing : mysql-server 75/106 Installing : cyrus-sasl-gssapi 76/106 Installing : php-gd 77/106 Installing : php-pgsql 78/106 Installing : php-mysql 79/106 Installing : dovecot 80/106 Installing : perl-DBD-Pg 81/106 Installing : mailman 82/106 Installing : mod_python 83/106 Installing : php-snmp 84/106 Installing : php-mbstring 85/106 Installing : php-xmlrpc 86/106 Installing : perl-Crypt-SSLeay 87/106 Installing : pam 88/106 Installing : libc-client 89/106 Installing : cyrus-sasl 90/106 Installing : postfix 91/106 Installing : php-imap 92/106 Installing : cyrus-sasl-gssapi 93/106 Installing : perl-libwww-perl 94/106 Installing : perl-XML-Parser 95/106 Installing : ruby-irb 96/106 Installing : spamassassin 97/106 Installing : ruby-rdoc 98/106 Installing : ruby-devel 99/106 Installing : rubygems 100/106 Installing : php-pear 101/106 Installing : mysql-devel 102/106 Installing : mysql-devel 103/106 Installing : ruby-devel 104/106 Installing : perl-XML-Simple 105/106 Cleanup : httpd 106/106 Installed: cyrus-sasl.i386 0:2.1.22-5.el5_4.3 cyrus-sasl-gssapi.i386 0:2.1.22-5.el5_4.3 cyrus-sasl-gssapi.x86_64 0:2.1.22-5.el5_4.3 dovecot.x86_64 0:1.0.7-7.el5 mailman.x86_64 3:2.1.9-4.el5 mod_dav_svn.x86_64 0:1.4.2-4.el5_3.1 mod_perl.x86_64 0:2.0.4-6.el5 mod_python.x86_64 0:3.2.8-3.1 mod_ssl.x86_64 2:2.2.3-43.3.vm mysql.i386 0:5.0.77-4.el5_5.4 mysql.x86_64 0:5.0.77-4.el5_5.4 mysql-devel.i386 0:5.0.77-4.el5_5.4 mysql-devel.x86_64 0:5.0.77-4.el5_5.4 mysql-server.x86_64 0:5.0.77-4.el5_5.4 perl-Crypt-SSLeay.x86_64 0:0.51-11.el5 perl-DBD-MySQL.x86_64 0:3.0007-2.el5 perl-DBD-Pg.x86_64 0:1.49-2.el5_3.1 perl-XML-Simple.noarch 0:2.14-4.fc6 php.x86_64 0:5.1.6-27.el5_5.3 php-gd.x86_64 0:5.1.6-27.el5_5.3 php-imap.x86_64 0:5.1.6-27.el5_5.3 php-mbstring.x86_64 0:5.1.6-27.el5_5.3 php-mysql.x86_64 0:5.1.6-27.el5_5.3 php-odbc.x86_64 0:5.1.6-27.el5_5.3 php-pear.noarch 1:1.4.9-6.el5 php-pgsql.x86_64 0:5.1.6-27.el5_5.3 php-snmp.x86_64 0:5.1.6-27.el5_5.3 php-xmlrpc.x86_64 0:5.1.6-27.el5_5.3 postfix.x86_64 2:2.3.3-2.1.el5_2 postgresql.x86_64 0:8.1.22-1.el5_5.1 postgresql-server.x86_64 0:8.1.22-1.el5_5.1 ruby.x86_64 0:1.8.5-5.el5_4.8 ruby-devel.i386 0:1.8.5-5.el5_4.8 ruby-devel.x86_64 0:1.8.5-5.el5_4.8 rubygems.noarch 0:0.9.2-1.el5 spamassassin.x86_64 0:3.2.5-1.el5 subversion.i386 0:1.4.2-4.el5_3.1 subversion.x86_64 0:1.4.2-4.el5_3.1 webalizer.x86_64 0:2.01_10-30.1 Dependency Installed: apr.i386 0:1.2.7-11.el5_5.3 apr-util.i386 0:1.2.7-11.el5_5.2 audit-libs.i386 0:1.7.17-3.el5 autoconf.noarch 0:2.59-12 automake.noarch 0:1.9.6-2.3.el5 cracklib.i386 0:2.8.9-3.3 cyrus-sasl-lib.i386 0:2.1.22-5.el5_4.3 db4.i386 0:4.3.29-10.el5_5.2 distcache.x86_64 0:1.4.5-14.1 e2fsprogs-devel.x86_64 0:1.39-23.el5_5.1 expat.i386 0:1.95.8-8.3.el5_5.3 fontconfig.x86_64 0:2.4.1-7.el5 freetype.x86_64 0:2.2.1-28.el5_5.1 gd.x86_64 0:2.0.33-9.4.el5_4.2 gdbm.i386 0:1.8.0-26.2.1 gmp.x86_64 0:4.1.4-10.el5 imake.x86_64 0:1.0.2-3 keyutils-libs-devel.x86_64 0:1.2-1.el5 krb5-devel.x86_64 0:1.6.1-36.el5_5.6 libX11.x86_64 0:1.0.3-11.el5 libXau.x86_64 0:1.0.1-3.1 libXdmcp.x86_64 0:1.0.1-2.1 libXpm.x86_64 0:3.5.5-3 libc-client.x86_64 0:2004g-2.2.1 libselinux-devel.x86_64 0:1.33.4-5.5.el5 libsepol-devel.x86_64 0:1.15.2-3.el5 libtermcap.i386 0:2.0.8-46.1 neon.i386 0:0.25.5-10.el5_4.1 neon.x86_64 0:0.25.5-10.el5_4.1 openldap.i386 0:2.3.43-12.el5_5.3 openssl-devel.x86_64 0:0.9.8e-12.el5_5.7 pam.i386 0:0.99.6.2-6.el5_5.2 perl-Archive-Tar.noarch 1:1.39.1-1.el5_5.2 perl-BSD-Resource.x86_64 0:1.28-1.fc6.1 perl-Compress-Zlib.x86_64 0:1.42-1.fc6 perl-DBI.x86_64 0:1.52-2.el5 perl-Digest-HMAC.noarch 0:1.01-15 perl-Digest-SHA1.x86_64 0:2.11-1.2.1 perl-HTML-Parser.x86_64 0:3.55-1.fc6 perl-HTML-Tagset.noarch 0:3.10-2.1.1 perl-IO-Socket-INET6.noarch 0:2.51-2.fc6 perl-IO-Socket-SSL.noarch 0:1.01-1.fc6 perl-IO-Zlib.noarch 0:1.04-4.2.1 perl-Net-DNS.x86_64 0:0.59-3.el5 perl-Net-IP.noarch 0:1.25-2.fc6 perl-Net-SSLeay.x86_64 0:1.30-4.fc6 perl-Socket6.x86_64 0:0.19-3.fc6 perl-URI.noarch 0:1.35-3 perl-XML-Parser.x86_64 0:2.34-6.1.2.2.1 perl-libwww-perl.noarch 0:5.805-1.1.1 php-cli.x86_64 0:5.1.6-27.el5_5.3 php-common.x86_64 0:5.1.6-27.el5_5.3 php-devel.x86_64 0:5.1.6-27.el5_5.3 php-pdo.x86_64 0:5.1.6-27.el5_5.3 pkgconfig.x86_64 1:0.21-2.el5 postgresql-libs.i386 0:8.1.22-1.el5_5.1 readline.i386 0:5.1-3.el5 ruby-irb.x86_64 0:1.8.5-5.el5_4.8 ruby-libs.i386 0:1.8.5-5.el5_4.8 ruby-libs.x86_64 0:1.8.5-5.el5_4.8 ruby-rdoc.x86_64 0:1.8.5-5.el5_4.8 sqlite.i386 0:3.3.6-5 unixODBC.x86_64 0:2.2.11-7.1 xorg-x11-filesystem.noarch 0:7.1-2.fc6 zlib-devel.x86_64 0:1.2.3-3 Updated: httpd.x86_64 1:2.2.3-43.3.vm Complete! INFO - 2011-04-06 19:23:32 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded. INFO - 2011-04-06 19:23:33 - Succeeded. INFO - 2011-04-06 19:23:33 - Installing Virtualmin and all related packages now using the command: INFO - 2011-04-06 19:23:33 - yum clean all INFO - 2011-04-06 19:23:34 - yum -y -d 2 install virtualmin-base Loaded plugins: fastestmirror Determining fastest mirrors * addons: mirrors.cmich.edu * base: mirrors.xmission.com * extras: mirror.metrocast.net * updates: mirror.ubiquityservers.com Setting up Install Process Resolving Dependencies --> Running transaction check ---> Package virtualmin-base.noarch 0:1.0-61.rh set to be updated --> Processing Dependency: usermin >= 1.160 for package: virtualmin-base --> Processing Dependency: webmin >= 1.334 for package: virtualmin-base --> Processing Dependency: wbt-virtual-server-mobile for package: virtualmin-base --> Processing Dependency: wbm-virtualmin-svn for package: virtualmin-base --> Processing Dependency: wbm-virtualmin-init for package: virtualmin-base --> Processing Dependency: scponly for package: virtualmin-base --> Processing Dependency: clamav for package: virtualmin-base --> Processing Dependency: wbm-virtualmin-dav for package: virtualmin-base --> Processing Dependency: proftpd for package: virtualmin-base --> Processing Dependency: cyrus-sasl-plain for package: virtualmin-base --> Processing Dependency: wbm-virtualmin-htpasswd for package: virtualmin-base --> Processing Dependency: wbm-virtualmin-mailman for package: virtualmin-base --> Processing Dependency: procmail-wrapper for package: virtualmin-base --> Processing Dependency: /usr/bin/freshclam for package: virtualmin-base --> Processing Dependency: wbm-security-updates for package: virtualmin-base --> Processing Dependency: wbm-php-pear for package: virtualmin-base --> Processing Dependency: wbt-virtual-server-theme for package: virtualmin-base --> Processing Dependency: wbm-virtualmin-awstats for package: virtualmin-base --> Processing Dependency: cyrus-sasl-md5 for package: virtualmin-base --> Processing Dependency: mod_fcgid for package: virtualmin-base --> Processing Dependency: wbm-virtualmin-registrar for package: virtualmin-base --> Processing Dependency: /usr/sbin/clamd for package: virtualmin-base --> Processing Dependency: wbm-virtual-server for package: virtualmin-base --> Processing Dependency: awstats for package: virtualmin-base --> Processing Dependency: ust-virtual-server-theme for package: virtualmin-base --> Processing Dependency: wbm-ruby-gems for package: virtualmin-base --> Running transaction check ---> Package awstats.noarch 0:6.8-1.el5 set to be updated ---> Package clamav.x86_64 0:0.96.5-1.vm.el5 set to be updated --> Processing Dependency: clamav-lib = 0.96.5-1.vm.el5 for package: clamav --> Processing Dependency: data(clamav) for package: clamav --> Processing Dependency: libclamav.so.6(CLAMAV_PUBLIC)(64bit) for package: clamav --> Processing Dependency: libclamav.so.6(CLAMAV_PRIVATE)(64bit) for package: clamav --> Processing Dependency: libclamav.so.6()(64bit) for package: clamav ---> Package clamav-server.x86_64 0:0.96.5-1.vm.el5 set to be updated --> Processing Dependency: clamav-filesystem = 0.96.5-1.vm.el5 for package: clamav-server --> Processing Dependency: init(clamav-server) for package: clamav-server ---> Package clamav-update.x86_64 0:0.96.5-1.vm.el5 set to be updated ---> Package cyrus-sasl-md5.x86_64 0:2.1.22-5.el5_4.3 set to be updated ---> Package cyrus-sasl-plain.x86_64 0:2.1.22-5.el5_4.3 set to be updated ---> Package mod_fcgid.x86_64 0:2.2-1.el5.vm set to be updated ---> Package procmail-wrapper.x86_64 0:1.0-1.vm set to be updated ---> Package proftpd.x86_64 0:1.3.3c-1.el5.vm set to be updated --> Processing Dependency: libGeoIP.so.1()(64bit) for package: proftpd ---> Package scponly.x86_64 0:4.6-1.vm set to be updated ---> Package usermin.noarch 0:1.460-1 set to be updated ---> Package ust-virtual-server-theme.noarch 2:6.9-1 set to be updated ---> Package wbm-php-pear.noarch 2:1.5-1 set to be updated ---> Package wbm-ruby-gems.noarch 2:1.4-1 set to be updated ---> Package wbm-security-updates.noarch 2:4.0-1 set to be updated ---> Package wbm-virtual-server.noarch 0:3.84.gpl-1 set to be updated ---> Package wbm-virtualmin-awstats.noarch 2:4.4-1 set to be updated ---> Package wbm-virtualmin-dav.noarch 2:3.3-1 set to be updated ---> Package wbm-virtualmin-htpasswd.noarch 2:2.4-1 set to be updated ---> Package wbm-virtualmin-init.noarch 2:2.1-1 set to be updated ---> Package wbm-virtualmin-mailman.noarch 2:6.0-1 set to be updated ---> Package wbm-virtualmin-registrar.noarch 2:2.0-1 set to be updated ---> Package wbm-virtualmin-svn.noarch 2:4.8-1 set to be updated ---> Package wbt-virtual-server-mobile.noarch 2:2.4-1 set to be updated ---> Package wbt-virtual-server-theme.noarch 2:8.0-1 set to be updated ---> Package webmin.noarch 0:1.530-1 set to be updated --> Running transaction check ---> Package GeoIP.x86_64 0:1.4.7-0.1.20090931cvs.el5 set to be updated ---> Package clamav-data.x86_64 0:0.96.5-1.vm.el5 set to be updated ---> Package clamav-filesystem.x86_64 0:0.96.5-1.vm.el5 set to be updated --> Processing Dependency: fedora-usermgmt for package: clamav-filesystem ---> Package clamav-lib.x86_64 0:0.96.5-1.vm.el5 set to be updated ---> Package clamav-server-sysv.x86_64 0:0.96.5-1.vm.el5 set to be updated --> Running transaction check ---> Package fedora-usermgmt.noarch 0:0.9-1.el5 set to be updated --> Processing Dependency: fedora-usermgmt-core = 0.9-1.el5 for package: fedora-usermgmt --> Processing Dependency: instance(fedora-usermgmt) for package: fedora-usermgmt --> Processing Dependency: setup(fedora-usermgmt) for package: fedora-usermgmt --> Running transaction check ---> Package fedora-usermgmt-core.noarch 0:0.9-1.el5 set to be updated ---> Package fedora-usermgmt-default-fedora-setup.noarch 0:0.9-1.el5 set to be updated ---> Package fedora-usermgmt-shadow-utils.noarch 0:0.9-1.el5 set to be updated --> Finished Dependency Resolution Dependencies Resolved ================================================================================ Package Arch Version Repository Size ================================================================================ Installing: virtualmin-base noarch 1.0-61.rh virtualmin 27 k Installing for dependencies: GeoIP x86_64 1.4.7-0.1.20090931cvs.el5 virtualmin 710 k awstats noarch 6.8-1.el5 virtualmin 1.2 M clamav x86_64 0.96.5-1.vm.el5 virtualmin 934 k clamav-data x86_64 0.96.5-1.vm.el5 virtualmin 25 M clamav-filesystem x86_64 0.96.5-1.vm.el5 virtualmin 18 k clamav-lib x86_64 0.96.5-1.vm.el5 virtualmin 4.4 M clamav-server x86_64 0.96.5-1.vm.el5 virtualmin 97 k clamav-server-sysv x86_64 0.96.5-1.vm.el5 virtualmin 18 k clamav-update x86_64 0.96.5-1.vm.el5 virtualmin 87 k cyrus-sasl-md5 x86_64 2.1.22-5.el5_4.3 base 47 k cyrus-sasl-plain x86_64 2.1.22-5.el5_4.3 base 27 k fedora-usermgmt noarch 0.9-1.el5 virtualmin 6.7 k fedora-usermgmt-core noarch 0.9-1.el5 virtualmin 7.7 k fedora-usermgmt-default-fedora-setup noarch 0.9-1.el5 virtualmin 6.6 k fedora-usermgmt-shadow-utils noarch 0.9-1.el5 virtualmin 7.4 k mod_fcgid x86_64 2.2-1.el5.vm virtualmin 124 k procmail-wrapper x86_64 1.0-1.vm virtualmin 4.8 k proftpd x86_64 1.3.3c-1.el5.vm virtualmin 3.5 M scponly x86_64 4.6-1.vm virtualmin 24 k usermin noarch 1.460-1 virtualmin-universal 6.2 M ust-virtual-server-theme noarch 2:6.9-1 virtualmin-universal 2.2 M wbm-php-pear noarch 2:1.5-1 virtualmin-universal 14 k wbm-ruby-gems noarch 2:1.4-1 virtualmin-universal 14 k wbm-security-updates noarch 2:4.0-1 virtualmin-universal 29 k wbm-virtual-server noarch 3.84.gpl-1 virtualmin-universal 1.6 M wbm-virtualmin-awstats noarch 2:4.4-1 virtualmin-universal 39 k wbm-virtualmin-dav noarch 2:3.3-1 virtualmin-universal 18 k wbm-virtualmin-htpasswd noarch 2:2.4-1 virtualmin-universal 18 k wbm-virtualmin-init noarch 2:2.1-1 virtualmin-universal 23 k wbm-virtualmin-mailman noarch 2:6.0-1 virtualmin-universal 42 k wbm-virtualmin-registrar noarch 2:2.0-1 virtualmin-universal 58 k wbm-virtualmin-svn noarch 2:4.8-1 virtualmin-universal 44 k wbt-virtual-server-mobile noarch 2:2.4-1 virtualmin-universal 71 k wbt-virtual-server-theme noarch 2:8.0-1 virtualmin-universal 2.2 M webmin noarch 1.530-1 virtualmin-universal 15 M Transaction Summary ================================================================================ Install 36 Package(s) Upgrade 0 Package(s) Total download size: 64 M Downloading Packages: -------------------------------------------------------------------------------- Total 229 kB/s | 64 MB 04:48 Running rpm_check_debug Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing : cyrus-sasl-md5 1/36 Installing : mod_fcgid 2/36 Installing : cyrus-sasl-plain 3/36 Installing : procmail-wrapper 4/36 Installing : GeoIP 5/36Operating system is CentOS Linux Installing : webmin 6/36Webmin install complete. You can now login to https://s1.dhonki.com:10000/ as root with your root password. Installing : wbm-virtual-server 7/36virtual-server Operating system is CentOS Linux Installing : usermin 8/36Usermin install complete. You can now login to https://s1.dhonki.com:20000/ as any user on your system. Installing : proftpd 9/36 Installing : ust-virtual-server-theme 10/36 Installing : wbm-virtualmin-svn 11/36virtualmin-svn Installing : wbm-virtualmin-mailman 12/36virtualmin-mailman Installing : wbm-virtualmin-dav 13/36virtualmin-dav Installing : wbm-virtualmin-htpasswd 14/36virtualmin-htpasswd Installing : wbm-virtualmin-awstats 15/36virtualmin-awstats Installing : wbm-virtualmin-registrar 16/36virtualmin-registrar Installing : wbm-security-updates 17/36security-updates Installing : wbm-ruby-gems 18/36ruby-gems Installing : wbt-virtual-server-theme 19/36 Installing : wbt-virtual-server-mobile 20/36 Installing : wbm-virtualmin-init 21/36virtualmin-init Installing : wbm-php-pear 22/36php-pear Installing : awstats 23/36 Installing : fedora-usermgmt-default-fedora-setup 24/36 Installing : scponly 25/36 Installing : fedora-usermgmt-core 26/36 Installing : fedora-usermgmt-shadow-utils 27/36 Installing : fedora-usermgmt 28/36 Installing : clamav-filesystem 29/36 Installing : clamav-data 30/36 Installing : clamav-lib 31/36 Installing : clamav 32/36 Installing : clamav-update 33/36 Installing : clamav-server 34/36 Installing : virtualmin-base 35/36Setting Webmin theme Setting Usermin theme Error occurred while setting Usermin theme: Failed to open PID file at ../web-lib-funcs.pl line 1340. Configuring Postfix Enabling Postfix and disabling Sendmail Setting up freshclam ClamAV update process started at Wed Apr 6 19:33:19 2011 DON'T PANIC! Read http://www.clamav.net/support/faq main.cvd is up to date (version: 53, sigs: 846214, f-level: 53, builder: sven) Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 0%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 1%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 2%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 3%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 4%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 5%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 6%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 7%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 8%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 9%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 10%] Downloading daily.cvd [ 11%] Downloading daily.cvd [ 11%] Downloading daily.cvd [ 11%] Downloading daily.cvd [ 11%] Downloading daily.cvd [ 11%] Downloading daily.cvd [ 11%] Downloading daily.cvd [ 11%] Downloading daily.cvd [ 11%] Downloading daily.cvd [ 11%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 12%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 13%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 14%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 15%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 16%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 17%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 18%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 19%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 20%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 21%] Downloading daily.cvd [ 22%] Downloading daily.cvd [ 22%] Downloading daily.cvd [ 22%] Downloading daily.cvd [ 22%] Downloading daily.cvd [ 22%] Downloading daily.cvd [ 22%] Downloading daily.cvd [ 22%] Downloading daily.cvd [ 22%] Downloading daily.cvd [ 22%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 23%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 24%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 25%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 26%] Downloading daily.cvd [ 27%] Downloading daily.cvd [ 27%] Downloading daily.cvd [ 27%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 28%] Downloading daily.cvd [ 29%] Downloading daily.cvd [ 29%] Downloading daily.cvd [ 29%] Downloading daily.cvd [ 29%] Downloading daily.cvd [ 29%] Downloading daily.cvd [ 29%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 30%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 31%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 32%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 33%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 34%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 35%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 36%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 37%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 38%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 39%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 40%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 41%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 42%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 43%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 44%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 45%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 46%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 47%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 48%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 49%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 50%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 51%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 52%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 53%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 54%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 55%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 56%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 57%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 58%] Downloading daily.cvd [ 59%] Downloading daily.cvd [ 59%] Downloading daily.cvd [ 59%] Downloading daily.cvd [ 59%] Downloading daily.cvd [ 59%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 60%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 61%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 62%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 63%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 64%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 65%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 66%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 67%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 68%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 69%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 70%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 71%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 72%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 73%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 74%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 75%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 76%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 77%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 78%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 79%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 80%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 81%] Downloading daily.cvd [ 82%] Downloading daily.cvd [ 82%] Downloading daily.cvd [ 82%] Downloading daily.cvd [ 82%] Downloading daily.cvd [ 82%] Downloading daily.cvd [ 83%] Downloading daily.cvd [ 83%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 84%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 85%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 86%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 87%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 88%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 89%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 90%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 91%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 92%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 93%] Downloading daily.cvd [ 94%] Downloading daily.cvd [ 94%] Downloading daily.cvd [ 94%] Downloading daily.cvd [ 94%] Downloading daily.cvd [ 94%] Downloading daily.cvd [ 94%] Downloading daily.cvd [ 94%] Downloading daily.cvd [ 94%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 95%] Downloading daily.cvd [ 96%] Downloading daily.cvd [ 96%] Downloading daily.cvd [ 96%] Downloading daily.cvd [ 96%] Downloading daily.cvd [ 96%] Downloading daily.cvd [ 96%] Downloading daily.cvd [ 96%] Downloading daily.cvd [ 97%] Downloading daily.cvd [ 97%] Downloading daily.cvd [ 97%] Downloading daily.cvd [ 97%] Downloading daily.cvd [ 97%] Downloading daily.cvd [ 97%] Downloading daily.cvd [ 97%] Downloading daily.cvd [ 98%] Downloading daily.cvd [ 98%] Downloading daily.cvd [ 98%] Downloading daily.cvd [ 98%] Downloading daily.cvd [ 98%] Downloading daily.cvd [ 98%] Downloading daily.cvd [ 98%] Downloading daily.cvd [ 99%] Downloading daily.cvd [ 99%] Downloading daily.cvd [ 99%] Downloading daily.cvd [ 99%] Downloading daily.cvd [ 99%] Downloading daily.cvd [ 99%] Downloading daily.cvd [ 99%] Downloading daily.cvd [ 99%] Downloading daily.cvd [100%] Downloading daily.cvd [100%] [LibClamAV] *********************************************************** [LibClamAV] *** This version of the ClamAV engine is outdated. *** [LibClamAV] *** DON'T PANIC! Read http://www.clamav.net/support/faq *** [LibClamAV] *********************************************************** daily.cvd updated (version: 12949, sigs: 96853, f-level: 60, builder: guitar) DON'T PANIC! Read http://www.clamav.net/support/faq Downloading bytecode.cvd [ 2%] Downloading bytecode.cvd [ 3%] Downloading bytecode.cvd [ 5%] Downloading bytecode.cvd [ 8%] Downloading bytecode.cvd [ 9%] Downloading bytecode.cvd [ 10%] Downloading bytecode.cvd [ 12%] Downloading bytecode.cvd [ 13%] Downloading bytecode.cvd [ 15%] Downloading bytecode.cvd [ 23%] Downloading bytecode.cvd [ 24%] Downloading bytecode.cvd [ 29%] Downloading bytecode.cvd [ 32%] Downloading bytecode.cvd [ 33%] Downloading bytecode.cvd [ 35%] Downloading bytecode.cvd [ 36%] Downloading bytecode.cvd [ 37%] Downloading bytecode.cvd [ 40%] Downloading bytecode.cvd [ 41%] Downloading bytecode.cvd [ 43%] Downloading bytecode.cvd [ 44%] Downloading bytecode.cvd [ 45%] Downloading bytecode.cvd [ 48%] Downloading bytecode.cvd [ 49%] Downloading bytecode.cvd [ 51%] Downloading bytecode.cvd [ 52%] Downloading bytecode.cvd [ 53%] Downloading bytecode.cvd [ 55%] Downloading bytecode.cvd [ 56%] Downloading bytecode.cvd [ 57%] Downloading bytecode.cvd [ 59%] Downloading bytecode.cvd [ 60%] Downloading bytecode.cvd [ 61%] Downloading bytecode.cvd [ 64%] Downloading bytecode.cvd [ 65%] Downloading bytecode.cvd [ 67%] Downloading bytecode.cvd [ 68%] Downloading bytecode.cvd [ 70%] Downloading bytecode.cvd [ 72%] Downloading bytecode.cvd [ 73%] Downloading bytecode.cvd [ 75%] Downloading bytecode.cvd [ 76%] Downloading bytecode.cvd [ 79%] Downloading bytecode.cvd [ 80%] Downloading bytecode.cvd [ 81%] Downloading bytecode.cvd [ 83%] Downloading bytecode.cvd [ 84%] Downloading bytecode.cvd [ 86%] Downloading bytecode.cvd [ 88%] Downloading bytecode.cvd [ 89%] Downloading bytecode.cvd [ 91%] Downloading bytecode.cvd [ 92%] Downloading bytecode.cvd [ 94%] Downloading bytecode.cvd [ 96%] Downloading bytecode.cvd [ 97%] Downloading bytecode.cvd [100%] Downloading bytecode.cvd [100%] [LibClamAV] *********************************************************** [LibClamAV] *** This version of the ClamAV engine is outdated. *** [LibClamAV] *** DON'T PANIC! Read http://www.clamav.net/support/faq *** [LibClamAV] *********************************************************** bytecode.cvd updated (version: 142, sigs: 40, f-level: 60, builder: acab) DON'T PANIC! Read http://www.clamav.net/support/faq Database updated (943107 signatures) from database.clamav.net (IP: 168.143.19.95) Configuring Dovecot for POP3 and IMAP Enabling Dovecot POP3 and IMAP servers Enabling ProFTPd Starting proftpd: [ OK ] Enabling SMTP authentication Starting saslauthd: saslauthd[13612] :detach_tty : Cannot start saslauthd saslauthd[13612] :detach_tty : Another instance of saslauthd is currently running [FAILED] Configuring Virtualmin Configuring Procmail Configuring Webalizer Updating /etc/shells Enabling MySQL and PostgreSQL Enabling Apache Configuring and enabling BIND Configuring resolv.conf to use local DNS server Configuring and enabling Mailman Enabling status monitoring Hiding the Webmin upgrade page Error occurred hiding Webmin upgrade page: Configuring firewall rules Allowing traffic on TCP port: ssh Allowing traffic on TCP port: smtp Allowing traffic on TCP port: domain Allowing traffic on TCP port: ftp Allowing traffic on TCP port: ftp-data Allowing traffic on TCP port: pop3 Allowing traffic on TCP port: pop3s Allowing traffic on TCP port: imap Allowing traffic on TCP port: imaps Allowing traffic on TCP port: http Allowing traffic on TCP port: https Allowing traffic on TCP port: 10000 Allowing traffic on TCP port: 20000 Allowing traffic on UDP port: domain Allowing traffic on UDP port: ftp Allowing traffic on UDP port: ftp-data Re-checking supported Webmin modules error: %post(virtualmin-base-1.0-61.rh.noarch) scriptlet failed, exit status 255 Installing : clamav-server-sysv 36/36 Installed: virtualmin-base.noarch 0:1.0-61.rh Dependency Installed: GeoIP.x86_64 0:1.4.7-0.1.20090931cvs.el5 awstats.noarch 0:6.8-1.el5 clamav.x86_64 0:0.96.5-1.vm.el5 clamav-data.x86_64 0:0.96.5-1.vm.el5 clamav-filesystem.x86_64 0:0.96.5-1.vm.el5 clamav-lib.x86_64 0:0.96.5-1.vm.el5 clamav-server.x86_64 0:0.96.5-1.vm.el5 clamav-server-sysv.x86_64 0:0.96.5-1.vm.el5 clamav-update.x86_64 0:0.96.5-1.vm.el5 cyrus-sasl-md5.x86_64 0:2.1.22-5.el5_4.3 cyrus-sasl-plain.x86_64 0:2.1.22-5.el5_4.3 fedora-usermgmt.noarch 0:0.9-1.el5 fedora-usermgmt-core.noarch 0:0.9-1.el5 fedora-usermgmt-default-fedora-setup.noarch 0:0.9-1.el5 fedora-usermgmt-shadow-utils.noarch 0:0.9-1.el5 mod_fcgid.x86_64 0:2.2-1.el5.vm procmail-wrapper.x86_64 0:1.0-1.vm proftpd.x86_64 0:1.3.3c-1.el5.vm scponly.x86_64 0:4.6-1.vm usermin.noarch 0:1.460-1 ust-virtual-server-theme.noarch 2:6.9-1 wbm-php-pear.noarch 2:1.5-1 wbm-ruby-gems.noarch 2:1.4-1 wbm-security-updates.noarch 2:4.0-1 wbm-virtual-server.noarch 0:3.84.gpl-1 wbm-virtualmin-awstats.noarch 2:4.4-1 wbm-virtualmin-dav.noarch 2:3.3-1 wbm-virtualmin-htpasswd.noarch 2:2.4-1 wbm-virtualmin-init.noarch 2:2.1-1 wbm-virtualmin-mailman.noarch 2:6.0-1 wbm-virtualmin-registrar.noarch 2:2.0-1 wbm-virtualmin-svn.noarch 2:4.8-1 wbt-virtual-server-mobile.noarch 2:2.4-1 wbt-virtual-server-theme.noarch 2:8.0-1 webmin.noarch 0:1.530-1 Complete! FATAL - 2011-04-06 19:34:37 - Fatal Error Occurred: Installation failed: 0 FATAL - 2011-04-06 19:34:38 - Cannot continue installation. FATAL - 2011-04-06 19:34:38 - Attempting to remove virtualmin repository configuration, so the installation can be FATAL - 2011-04-06 19:34:38 - re-attempted after any problems have been resolved. FATAL - 2011-04-06 19:34:38 - Removing temporary directory and files. FATAL - 2011-04-06 19:34:38 - If you are unsure of what went wrong, you may wish to review the log FATAL - 2011-04-06 19:34:38 - in /root/virtualmin-install.log
