hi. i had install phpmyadmin in to a custom folder with the new script installer wich come with virtualmin. i want to uninstall but i can’t. i receive “Error - File not found” on the right frame.
what to do. thanks.
That’s a bug in Virtualmin 3.84 – it’ll be fixed in 3.85.
One work around is that if you go into Install Scripts, and click the script name, try clicking the Un-Install Script button from there… that may allow you to remove it.
