I’m migrating my website to a new server on Debian 9, both old & new servers use VirtualMin 6.08.
On the new server, I can’t connect by FTP (nor FTP/TLS) remotely. It’s working locally, but remotely it just times out without any message.
I tried this without success : FTP connection refused by server | Virtualmin .
Proftp is listening on the port 21 :
lsof -i :21
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
proftpd 8212 proftpd 0u IPv6 19031762 0t0 TCP *:ftp (LISTEN)
Log has 0 trace of my login attempts :
cat /var/log/proftpd/proftpd.log
2020-01-25 16:59:35,331 my–website–com proftpd[1409] my–website–com (localhost[127.0.0.1]): FTP session opened.
2020-01-25 17:00:35,999 my–website–com proftpd[1409] my–website–com (localhost[127.0.0.1]): FTP session closed.
2020-01-25 17:15:16,587 my–website–com proftpd[13021] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:15:16,600 my–website–com proftpd[13021] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:15:46,012 my–website–com proftpd[13216] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:16:01,482 my–website–com proftpd[13216] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:16:11,595 my–website–com proftpd[13412] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:16:20,952 my–website–com proftpd[13412] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:16:31,077 my–website–com proftpd[13543] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:16:34,351 my–website–com proftpd[13543] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:16:44,430 my–website–com proftpd[13626] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:16:50,089 my–website–com proftpd[13626] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:17:00,166 my–website–com proftpd[13731] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:17:02,553 my–website–com proftpd[13731] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:17:12,672 my–website–com proftpd[13824] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:17:12,853 my–website–com proftpd[13824] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:17:22,949 my–website–com proftpd[13881] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:17:23,163 my–website–com proftpd[13881] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:17:33,241 my–website–com proftpd[13956] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:17:39,198 my–website–com proftpd[13956] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:17:49,334 my–website–com proftpd[14064] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:17:49,503 my–website–com proftpd[14064] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:17:59,598 my–website–com proftpd[14143] 0.0.0.0 (–myip–): SSH2 session opened.
2020-01-25 17:18:01,511 my–website–com proftpd[14143] 0.0.0.0 (–myip–): SSH2 session closed.
2020-01-25 17:19:20,515 my–website–com proftpd[27036] my–website–com: ProFTPD killed (signal 15)
2020-01-25 17:19:20,515 my–website–com proftpd[27036] my–website–com: ProFTPD 1.3.5b standalone mode SHUTDOWN
2020-01-25 17:19:21,619 my–website–com proftpd[16253] my–website–com: ProFTPD 1.3.5b (maint) (built Wed Oct 23 2019 21:34:50 UTC) standalone mode STARTUP
2020-01-25 17:23:17,118 my–website–com proftpd[16253] my–website–com: ProFTPD killed (signal 15)
2020-01-25 17:23:17,119 my–website–com proftpd[16253] my–website–com: ProFTPD terminating (signal 7)
2020-01-25 17:23:17,119 my–website–com proftpd[16253] my–website–com: FTP session closed.
2020-01-25 17:23:18,228 my–website–com proftpd[18813] my–website–com: ProFTPD 1.3.5b (maint) (built Wed Oct 23 2019 21:34:50 UTC) standalone mode STARTUP
2020-01-25 17:24:51,879 my–website–com proftpd[18813] my–website–com: ProFTPD killed (signal 15)
2020-01-25 17:24:51,879 my–website–com proftpd[18813] my–website–com: ProFTPD 1.3.5b standalone mode SHUTDOWN
2020-01-25 17:24:52,983 my–website–com proftpd[21261] my–website–com: ProFTPD 1.3.5b (maint) (built Wed Oct 23 2019 21:34:50 UTC) standalone mode STARTUP
2020-01-25 17:25:13,876 my–website–com proftpd[21261] my–website–com: ProFTPD killed (signal 15)
2020-01-25 17:25:13,876 my–website–com proftpd[21261] my–website–com: ProFTPD 1.3.5b standalone mode SHUTDOWN
2020-01-25 17:25:15,130 my–website–com proftpd[21572] my–website–com: ProFTPD 1.3.5b (maint) (built Wed Oct 23 2019 21:34:50 UTC) standalone mode STARTUP
2020-01-25 18:37:33,158 my–website–com proftpd[21572] my–website–com: ProFTPD killed (signal 15)
2020-01-25 18:37:33,159 my–website–com proftpd[21572] my–website–com: ProFTPD 1.3.5b standalone mode SHUTDOWN
2020-01-25 18:37:34,268 my–website–com proftpd[8212] my–website–com: ProFTPD 1.3.5b (maint) (built Wed Oct 23 2019 21:34:50 UTC) standalone mode STARTUP
(the 1st connection is local)
SSH doesn’t work either, failing with a message, though :
Error: FATAL ERROR: Network error: Connection refused
As I had activated the FTP/TLS (following FTPeS (Working Solution on Debian with Virtualmin/Webmin) | Virtualmin ) on my old server, I tried to activate it as well on the new server, but it didn’t change anything either.
Thanks in advance for any help !
