duell
September 22, 2011, 2:03pm
1
Can’t connect to virtualmin:10000 after reboot.
After a fresh install ubuntu 10.04 lts + virtualmin everything seems te be working. I can connect to virtualmin by browsing to https//:10000.
The weird thing is, after reboot virtualmin is not reachable anymore.
Error on firefox :
Firefox can’t establish a connection to the server at :10000.
Listing iptables, all ports are open.
sudo iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
I’ve already tried atleast 6 fresh install of ubuntu + virtualmin. Same result everytime. After reboot, I can’t connect to virtualmin.
Does anyone have this same problem?
Eric
September 22, 2011, 2:18pm
2
It sounds like you might be seeing the Ubuntu startup script bug… Virtualmin may simply not be starting up properly.
A quick fix is just to launch it manually:
/etc/init.d/webmin start
There’s a forum thread about that here:
https://www.virtualmin.com/node/19092
The way to resolve so it starts up next time is to run this command:
update-rc.d webmin defaults
duell
September 23, 2011, 6:44am
3
You’re right!
“update-rc.d webmin defaults” did the trick.
I still have connection issues after clean installation of Virtualmin. I ran the provided command but it didn;t do the trick.
Any ideas why?
Eric
August 10, 2015, 5:35pm
5
What is the output of this command:
netstat -an | grep :10000
Also, what error are you receiving in you browser when trying to connect to port 10000?
Hello Eric,
Thanks for taking the time to reply. I already figured it out. I can swear I enabled the port 10000 but apparently I hadn’t. That was the whole problem.
