Cannot load domains after upgrade
OS type and version Debian 13
Virtualmin version 8.0.1
Hi I followed a tutorial to get debian 12 to 13 and rebooted my Linode.
Virtualmin works, but not my websites.
they suggest a The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
webpage.
I have recently tried to restore these from a backup.
But still haviing trouble loading them.
MyVapingright.com
is one of my main domains.
now i cant create backups saying ran out of space when i have about 130 gib left and the backup would only be less than 5 gib
Website is working. Vaping? Really?
A recent thread on backup is only a few posts down.
Maybe post a error from the backup process, very hard to help when you don’t give much info.
I’ve never use a upgrade process (major version change only), when I upgrade the server I will created a new instance with the new OS and install Virtuamin to the clean system then restore from that lastest Virtualmin backup. I have a “portable IP” that I can then move to the new instance so no dns changes needed.
You’ve got to look at logs (PHP error log, probably for this specific error, but there might be clues in the web server error log).
Don’t change the subject. Make another topic.
I had to do a new linode and fresh install, then reimport backups and it is now working.
