Can not send and receive emails
Of course there maybe no auth method running but as the OP is unwilling to share what changes they have made you will be running around in circle’s good luck
Make a backup of your master.cf
Than paste this in your master.cf replacing all your text (you are missing a part of it)
# Postfix master process configuration file.  For details on the format
# of the file, see the master(5) manual page (command: "man 5 master" or
# on-line: http://www.postfix.org/master.5.html).
# Do not forget to execute "postfix reload" after editing this file.
# service type  private unpriv  chroot  wakeup  maxproc command + args
#               (yes)   (yes)   (no)    (never) (100)
smtp	inet	n	-	y	-	-	smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may
#smtp      inet  n       -       y       -       1       postscreen
#smtpd     pass  -       -       y       -       -       smtpd
#dnsblog   unix  -       -       y       -       0       dnsblog
#tlsproxy  unix  -       -       y       -       0       tlsproxy
# Choose one: enable submission for loopback clients only, or for any client.
#127.0.0.1:submission inet n -   y       -       -       smtpd
#submission inet n       -       y       -       -       smtpd
#  -o syslog_name=postfix/submission
#  -o smtpd_tls_security_level=encrypt
#  -o smtpd_sasl_auth_enable=yes
#  -o smtpd_tls_auth_only=yes
#  -o smtpd_reject_unlisted_recipient=no
#  -o smtpd_client_restrictions=$mua_client_restrictions
#  -o smtpd_helo_restrictions=$mua_helo_restrictions
#  -o smtpd_sender_restrictions=$mua_sender_restrictions
#  -o smtpd_recipient_restrictions=
#  -o smtpd_relay_restrictions=permit_sasl_authenticated,reject
#  -o milter_macro_daemon_name=ORIGINATING
# Choose one: enable smtps for loopback clients only, or for any client.
#127.0.0.1:smtps inet n  -       y       -       -       smtpd
#smtps     inet  n       -       y       -       -       smtpd
#  -o syslog_name=postfix/smtps
#  -o smtpd_tls_wrappermode=yes
#628       inet  n       -       y       -       -       qmqpd
pickup    unix  n       -       y       60      1       pickup
cleanup   unix  n       -       y       -       0       cleanup
qmgr      unix  n       -       n       300     1       qmgr
#qmgr     unix  n       -       n       300     1       oqmgr
tlsmgr    unix  -       -       y       1000?   1       tlsmgr
rewrite   unix  -       -       y       -       -       trivial-rewrite
bounce    unix  -       -       y       -       0       bounce
defer     unix  -       -       y       -       0       bounce
trace     unix  -       -       y       -       0       bounce
verify    unix  -       -       y       -       1       verify
flush     unix  n       -       y       1000?   0       flush
proxymap  unix  -       -       n       -       -       proxymap
proxywrite unix -       -       n       -       1       proxymap
smtp      unix  -       -       y       -       -       smtp
relay     unix  -       -       y       -       -       smtp
        -o syslog_name=postfix/$service_name
#       -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq     unix  n       -       y       -       -       showq
error     unix  -       -       y       -       -       error
retry     unix  -       -       y       -       -       error
discard   unix  -       -       y       -       -       discard
local     unix  -       n       n       -       -       local
virtual   unix  -       n       n       -       -       virtual
lmtp      unix  -       -       y       -       -       lmtp
anvil     unix  -       -       y       -       1       anvil
scache    unix  -       -       y       -       1       scache
postlog   unix-dgram n  -       n       -       1       postlogd
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent.  See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop  unix  -       n       n       -       -       pipe
  flags=DRXhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
#   lmtp    cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
#  mailbox_transport = lmtp:inet:localhost
#  virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus     unix  -       n       n       -       -       pipe
#  flags=DRX user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix  -       n       n       -       -       pipe
#  flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
uucp      unix  -       n       n       -       -       pipe
  flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
ifmail    unix  -       n       n       -       -       pipe
  flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp     unix  -       n       n       -       -       pipe
  flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix -       n       n       -       2       pipe
  flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman   unix  -       n       n       -       -       pipe
  flags=FRX user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py ${nexthop} ${user}
submission	inet	n	-	y	-	-	smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may
smtps	inet	n	-	y	-	-	smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may -o smtpd_tls_wrappermode=yes
did it but unfortunately didn’t solved
Did you restart Postfix?
yes i restart postfix
Send an email to another recipient email (if you sent to yahoo, send now to google) and put the /var/log/mail output here.
Also check Postfix > Mail Queue and take a screenshot.
And you can check your email server setup with Domain Health Check - Online Domain Tools - Blacklist, Email, Website, DNS - MxToolBox or wormly
log file is still :fatal: no SASL authentication mechanisms
and about the website i have 3 errors on mail server :
spf : No SPF Record found
dmarc :No DMARC Record found
mx :No DMARC Record found
and also :Reverse DNS does not match SMTP Banner
Virtualmin should setup that after you choose them, except PTR (Reverse DNS) but that is important only to a few email providers that bouce your emails (you need first to send them…)
Try google the exact error. Plenty of people had the same issue.
Thank you so much , this solved sending email problem . i wish you a happy life :heart:
Congratz, happy mailing
You can close it
