I disabled those options from Webmin and now my computer works better
Can I disable these process? What I lose disabling them? Thank you!
PD: Sorry for my Spanglish…
You can tell it to run less frequently if you like… that can be configured in System Settings -> Virtualmin Config -> Status Collection.
In there, you can set it to run once an hour, or perhaps once a day.
That’s no problem to do that, it’s just various stats collections.
Thanks so much! I set 1440 minutes = 1 day
When I change that, the following error apear when I try to check configuration:
An error was detected in the new Cron configuration :
crontab: installing new crontab
"/tmp/crontab.Bh2gwg/crontab":1: bad day-of-week
errors in crontab file, can't install.
Do you want to retry the same edit? crontab: edits left in /tmp/crontab.Bh2gwg/crontab
# DO NOT EDIT THIS FILE - edit the master and reinstall.
# (/tmp/crontab.XkhyCY/crontab installed on Thu Jul 12 10:07:27 2012)
# (Cron version -- $Id: crontab.c,v 2.13 1994/01/17 03:20:37 vixie Exp $)
14 21 * * * /etc/webmin/virtual-server/sendratings.pl
* * * * /etc/webmin/virtual-server/collectinfo.pl
12 22 * * * /etc/webmin/virtual-server/scriptlatest.pl
0,5,10,15,20,25,30,35,40,45,50,55 * * * * /etc/webmin/status/monitor.pl
17 * * * * /etc/webmin/virtual-server/spamconfig.pl
54 0 * * * /etc/webmin/webalizer/webalizer.pl /var/log/virtualmin/{SERVER}_access_log
46 4 * * * /etc/webmin/virtualmin-awstats/awstats.pl {SERVER}
22 1 * * * /etc/webmin/webalizer/webalizer.pl /var/log/virtualmin/{SUBSERVER}.{SERVER}_access_log
3 17 * * * /etc/webmin/virtualmin-awstats/awstats.pl {SERVER}
39 0 * * * /etc/webmin/webalizer/webalizer.pl /var/log/virtualmin/wi_access_log
56 8 * * * /etc/webmin/virtualmin-awstats/awstats.pl wi
35 4 * * * /etc/webmin/webalizer/webalizer.pl /var/log/virtualmin/{SUBSERVER}.{SERVER}_access_log
29 21 * * * /etc/webmin/virtualmin-awstats/awstats.pl {SUBSERVER}.{SERVER}
54 2 * * * /etc/webmin/webalizer/webalizer.pl /var/log/virtualmin/{SUBSERVER}.{SERVER}_access_log
53 22 * * * /etc/webmin/virtualmin-awstats/awstats.pl {SUBSERVER}.{SERVER}
35 3 * * * /etc/webmin/webalizer/webalizer.pl /var/log/virtualmin/{SUBSERVER}.{SERVER}_access_log
52 1 * * * /etc/webmin/virtualmin-awstats/awstats.pl {SUBSERVER}.{SERVER}
What can I do to resolve that?
Hmm, it’s possible that timeframe is confusing it… what if you input 60 instead, does that work?
“/tmp/crontab.Bh2gwg/crontab”:1: bad day-of-week
errors in crontab file, can’t install.
If I try with 60 (or 90) sometimes works, sometimes not. When I test twice (or more) times with value 1440 the checking show: ‘Your system is ready for use by Virtualmin’. Is it Ok?
