did you find anything on his server that may help me ?
Things were working as designed on the original posters system…bw.pl is demanding. There is nothing we can do to make tracking every packet in and out of the system not require some resources–memory, CPU, and disk space.
Are you sure it’s the same bw.pl process? Check to PID each time you check. In the cases I’ve looked into, the bw.pl process starts, runs for 20-30 seconds, and then exits correctly. Then, a few minutes later, a new one starts, runs for 20-30 seconds, exits, and so one. If you’re not watching closely, it could seem like bw.pl is “always running” because it’s running often and at a high CPU usage.
Be sure you’re seeing what you think you’re seeing.
bw.pl is set to run as “nice” as possible–so it won’t use CPU that other processes want, but it will use as much as it can without stepping on other processes. This also means that if your box is working hard on other tasks (like mail delivery) bw.pl could run for longer than 20-30 seconds, as it is waiting for its share of the CPU to be available.
So, to sum up:
bw.pl is demanding, and will always be demanding. This is not a bug–it has a lot of work to do.
bw.pl probably isn’t running forever, but it might run longer than it should, if other processes are demanding a lot of CPU. Make sure everything else on the system is running as efficiently as possible. Mail processing is the obvious first candidate for efficiency improvements. Switch to the daemonized versions of spam and AV processing, if you haven’t already.
If, you are, in fact seeing bw.pl (the same PID) run for more than a couple of minutes, then there’s probably a bug, and I’d want to look at it. But, we haven’t had a bug report about bw.pl in at least a year that turned out to be an actual bug–it’s pretty much always just that bw.pl is demanding, and people want it to be less demanding. We’d like that too, but Jamie’s tuned it as much as is reasonable–we’ve tinkered with compiled log parsers and other stuff, but they turn out to be no faster (or even slower) than the Perl parser simply because Perls’ regex engine and text processing tools are incredibly efficient by most measures (including when stacked up against tools in compiled languages).
But, we do want to know about it, if there is actually a misbehavior–I don’t mean to sound discouraging. It just comes up a lot.
