Hi guys, I’m new, as the title that I tried to build a web server using Virtualmin at home but my ISP (Suddenlink) blocked port 80, therefore I got stuck at the step request SSL from Lets-encrypt. I did research and followed to do it before creating a new topic, but most of the post I read has some same kind with me (ISP blocked port 80) is outdated and it so different to follow. So can you guys give me some advice with a pathway should I follow, any link with a new update, or any step-by-step? Thank you!
Operating system and OS version: Ubuntu Server 20.04 LTS
Ports opened: 22, 80, 8080, 8081, 443, 10000, 20-21, 25, 53, 110, 143, 993, 465, 10001-10009, 20000
Domain Registrar: Namecheap
Steps has tried:
- Enable SSL for virtual server and request SSL from Let’s Encrypt in Virtualmin (http-01 Challenge failed because ISP blocked port 80)
- Change the HTTP port to another differ from 80 (8080, 8081) and did the same with above. (the challenge still failed)
- I did run
certbot certonly --manual --preferred-challenges dns -d vietfoodsquad.xyz -d www.vietfoodsquad.xyz -d mail.vietfoodsquad.xyz -d admin.vietfoodsquad.xyz -d webmail.vietfoodsquad.xyz
and
acme.sh --issue -d vietfoodsquad.xyz -d www.vietfoodsquad.xyz -d mail.vietfoodsquad.xyz -d admin.vietfoodsquad.xyz -d webmail.vietfoodsquad.xyz -w /home/vietfoodsquad/public_html
(It still fail to challenge, idk, I think some of my step for doing these two is wrong, if your recommend is these two, could you write the step-by-step again for me?) - Follow the step from Cloudflare to add nameserver to Namecheap, turn on full in SSL/TLS tab. (This seem to work well but now the new problem is I could not enter back into Virtualmin and my router, the only thing I could access is vietfoodsquad.xyz, so if you recommend this method can you also again write me the step?)
