Has anyone tried enable Brotli Compression?
I found how to install it, its supposed to be better then Gzip
Steve
Steve
It is, marginally. On text files it can compress between 10% and 15% smaller than Gzip. The problem though is that Gzip has been around for nearly 30 years now and Brotli has only been around for 5 or 6 years. I always err on the side of caution and stick with the tried and true.
@Gomez_Adams exactly plus gzip support not only text. brotli okay fine but not need it to even have look at it.
I only know about its performance on text files. I have no clue what it does for video, etc.
Well from the wiki, Brotli compression is generally used as an alternative to gzip, as Brotli provides better overall compression.[11] Compared to gzip compression, JavaScript files compressed with Brotli are roughly 15% smaller, HTML files are around 20% smaller, and CSS files are around 16% smaller.
Something for the future, or now.
Steve
