Blocking top level domain
Hi, I want to block the top level domain .info. In the spamassassin mail filter module under allowed denied addresses I added the following. Is this the correct way to do it?
*.info
Thank you.
Hmm, I’m not entirely certain, I hadn’t tried to block an entire top level domain before.
What you have there may work… if it doesn’t, I suspect this would:
@.info
Thanks! I will try your suggestion I’ll let you know if it works.
