Setup:
OS : Ubuntu Lucid (10.04.2) x64
Virtualmin : 3.8.4 Pro
Install Script PHPCoin version 1.6.5
PHP : 5.3.2
Apache : 2.2.14
Running Suexec with FCGID
Situation:
Fresh Script Install PHPCoin 1.6.5
Blank screen when clicking on link to http://mydomain.com/phpcoin
No Errors Reported
Solution:
To enable errors, comment out ini_set statements in phpcoin/coin_includes/session_set.php
# Turn off pointless "warning" messages, and display errors on-screen
#ini_set('error_reporting','E_ALL & ~E_NOTICE');
#ini_set('display_errors', 1);
Edit Php 5 Configuration for the site in Virtualmin
Set Display error messages to Yes
Make sure E_ALL is in the error types to display or
if you have checkboxes, select the All errors and warnings
Refresh your browser window pointed at phpcoin
Should get the following error :
Fatal error: Cannot redeclare quoted_printable_encode()
Edit phpcoin/coin_includes/core.php
Search for: function quoted_printable_encode
Wrap the function with the following if condition :
if(!function_exists('quoted_printable_encode')) {
#Original function here
Save
Refresh browser pointed at phpcoin
Should display correctly
~Jeremy
