Hi i have a problem with virtualmin/wemin server.
After the update (from original source) and login, the virtualmin webpage it’s blank.
This is a server with LAMP CENTOS 6, all site installed works and console it’s ok, but the webpage no.
It’s possible to find a solution without deleting anything or losing data?
Thank’s a lot.
We will try and assist, @adlsrl. All your websites, their content and databases appear to be intact, so don’t worry unduly. It is possible to find a solution without deleting anything or losing data.
Let’s see if we can get Virtualmin to work again. Could you:
sudo service webmin restart
sudo service usermin restart
Well, a step-by-step guide is not necessary as updates are supposed to be flawless for the most part. Unfortunately for you it was not and a possible reason for it could be the theme, though we don’t know for sure if that’s the actual reason. Diagnosis by means of forum messages can be such fun.
I am at a loss about what to do next. If I was at the terminal then I would check for a few things. If I knew your domain name or IP address then I would look for errors (right-click | Inspect) in the browser which might give me more clues.
Since I do not have access to either, I am stuck. Maybe someone else can suggest other approaches.
Be assured that your websites and data are not lost, even though my initial attempt at resolving this was unsuccessful.
That’s correct, @adlsrl. All sites are up because ports 80 and 443 have been configured to be open in the firewall of Virtualmin as well as any firewall that your VPS host / service provider may offer. However Virtualmin GUI uses port 10000 which may not be open - this seems to be the case based on what I have seen so far. You need to confirm that it is open before we can diagnose this issue further.
Perhaps your VPS host / service provider can assist if you open a trouble ticket with them - just say that you need to let people access port 10000 from the net so could they configure the firewall accordingly.
Log for firewall offered by your VPS host / service provider? I don’t know…
Let’s try something wild that may get you access to Virtualmin even if port 10000 in not open in the VPS host / service provider firewall! This method is perfectly safe and easily reversible if it does not work. In Virtualmin -> antoniodellalibera.it (or any other domain) -> Server Configuration -> Edit Proxy Website, in the " Proxy to URL" field, enter https://80.88.91.147:10000/ and set “Proxying enabled?” to yes. Click “Save and Apply”.
Then open https://www.antoniodellalibera.it/ in the browser. If everything works as I expect, you should see the Virtualmin GUI / login screen instead of the normal website associated with the domain.
hi, what time zone youre in? I can have look with you, if you dont mind voice call / video call over whatsapp - I actually would like to see what is happening when you load your page from your side. No need to control your pc or anything but we can do via teamviewer or just your phone camera and do trouble shooting as we speak… let me know.
