- I have set up 4 new virtualmin servers. (Scientific Linux 6.3 and named vm1 - vm4
- The firewall of each server is set to the option “Block all except ports used for virtual hosting”. So also port 53 is stated “accepted”
- On every server I add (Webmin Server Index) all the other servers. I use ns1 - ns4 because they pointed to the correct corersponding ip-adresses.
- Also did that on cluster name servers within bind configuration
When I add a new server it creates this also on the slave servers. This is working fine. But the value of this domain is empty.
When I excecute the command within virtualmin “test zone transfer” then it says for al the servers (I use xx by purpose due to privacy):
from 1xx.43.xx.140 : Failed : ;; Connection to 1xx.43.xx.140#53(1xx.43.xx.140) for mydomain.com failed: connection refused.
and so on
I tried a zone transfer also with the firewall on all servers off: same problem.
With the firewall on the command: netstat -an | grep :53 give the folowing output (again xx are used for privacy reasons:
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN
tcp 0 52 1xx.43.xx.149:22 2xx.122.1xx.52:53019 ESTABLISHED
tcp 0 0 ::1:53 :::* LISTEN
udp 0 0 127.0.0.1:53 0.0.0.0:*
udp 0 0 ::1:53 :::*
What did I have done wrong? Please help me on this.
