Bind Problem
I keep getting this error when trying to download / update the root zone. The current file has nothing in it.
Failed to re-download root zone : Failed to write to /var/named/run-root/var/named/run-root/var/named.root : Bad file descriptor
I am getting the bad file descriptor issue when creating master zones. If a master zone get created it can not find the file because it did not create it.
I am lost can anyone help?
Also why is the file being called from /var/named/run-root/var/named/run-root/var/named.root and not
/var/named/run-root/var/ZONE_FILE ?
