I have a problem with the configuration of my DNS server (public resolver) at the moment.
It works fine, but I have an error in the logs, a few seconds after starting bind :
managed-keys-zone: Unable to fetch DNSKEY set ‘.’: timed out
I’m running Debian 11 with BIND 9.16.50-Debian (Extended Support Version).
Here are the little things I tried:
- I’ve updated my db.root from https://www.internic.net/domain/named.root
- I’ve deleted the cached keys (the files do contain updated KEYDATA) : rm /var/cache/bind/managed-keys.bind*
- netstat -tulpnW | grep 53 / ss -ntlp | grep :53 : all I have is named.
- telnet -4 127.0.0.1 53 : connects successfully to the server.
- dig +dnssec . DNSKEY @127.0.0.1 : flag qr rd ra ad, and compliant answers.
- dig +dnssec . DNSKEY @a.root-servers.net : flag qr aa rd, and compliant answers.
- All is ok in iptable.
My file /etc/bind/named.conf :
include "/etc/bind/named.conf.options";
include "/etc/bind/named.conf.local";
include "/etc/bind/named.conf.default-zones";
key rndc-key {
algorithm hmac-sha256;
secret "secret-key";
controls {
inet 127.0.0.1 port 953 allow { 127.0.0.1; } keys { "rndc-key"; };
My file /etc/bind/named.conf.options :
acl "trusted" {
localhost;
ip-ns-master;
ip-ns-slave;
options {
directory "/var/cache/bind";
listen-on { 127.0.0.1; ip-ns-master; };
listen-on-v6 { none; };
version none;
auth-nxdomain no;
dnssec-validation auto;
managed-keys-directory "/var/cache/bind";
allow-query { any; };
allow-recursion { trusted; };
allow-query-cache { trusted; };
allow-transfer { trusted; };
My file /etc/bind/named.conf.local (example zone) :
zone "domain.com" {
type master;
notify yes;
allow-transfer { ip-ns-slave; };
dnssec-policy none;
file "/var/lib/bind/domain.com.hosts";
My file /etc/bind/named.conf.default-zones :
zone "." {
type hint;
file "/etc/bind/db.root";
[... +local ...]
My file rndc.conf :
key "rndc-key" {
options {
default-key "rndc-key";
default-server 127.0.0.1;
default-port 953;
My file /etc/resolv.conf :
domain datacenter-domain
search datacenter-domain
nameserver 127.0.0.1
nameserver datacenter-nameserver-1-ip
nameserver datacenter-nameserver-2-ip
If you have any ideas on how to solve this problem, I’d be grateful.
