virtualmin is reporting BIND DNS Server is not running and i am able to get to all sites i have configured.
bind is running as indicated by ps auxw | grep named
bind 9238 0.0 0.3 52892 11104 ? Ssl 18:29 0:00 /usr/sbin/named -u bind
root 9545 0.0 0.2 51220 9640 ? Ssl 18:33 0:00 /usr/sbin/named -c /etc/bind/named.conf
a check of my config says
i have tried to restart bind with no luck.
i am running
virtualmin 3.76 gpl
Debian lenny
could someone tell me what i can check to resolve this problem
update i did notice the
BIND DNS Server link points to xxx.xxx.xxx.xxx:10000/bind8/
i am running bind9
Eric
2
Is that a new problem, or have you had that issue ever since installing Virtualmin?
Is BIND taking awhile to respond? If you run this command from your server, what output do you get:
time host google.com
google.com has address 72.14.204.104
google.com has address 72.14.204.147
google.com has address 72.14.204.99
google.com has address 72.14.204.103
google.com mail is handled by 10 google.com.s9a1.psmtp.com.
google.com mail is handled by 10 google.com.s9a2.psmtp.com.
google.com mail is handled by 10 google.com.s9b1.psmtp.com.
google.com mail is handled by 10 google.com.s9b2.psmtp.com.
real 0m1.513s
user 0m0.004s
sys 0m0.004s
this happened after upgrading virtualmin to ver 2.76 from 2.72
Eric
4
Yeah, I’m not really sure – your DNS seems to be working, and responding quickly.
I might suggest filing a bug report, and say that after your recent upgrade, you’re getting the above messages.
