Setting up bind-chroot and can’t seem to get the module config right?
chroot directory where /var/named/is mounted: /var/named/chroot/
named.conf and named.rfc1912.zones are located in /etc/, and get mounted to the chroot directory (/var/named/chroot/etc/).
VM is seeing zones fine but when I try to do anything, it tries to save changes to files in the chroot rather than the non-chroot;
Failed to create master zone : Failed to replace /var/named/chroot/etc/named.conf with /var/named/chroot/etc/named.conf.webmintmp.40723 : Device or resource busy
The only way I can seem to get it to work is to direct it to where the edit files are and tell the module that it’s not chroot’d, but when I do it that way it doesn’t reload named.
