I’m looking for an alternative to the Hezner storage box.
It needs to have these options
- SFTP
- 512 GB - 1 TB storage
- EU location
- Other Provider than Hetzner.
I need it to back up my Virtualmin Server
Did anyone have a good host???
Regedss
Thomas
Regedss
Thomas
Check these out:
And, if you’re fine switching from SFTP to object storage, Scaleway has S3-compatible storage.
With ScaleWay you can get a 1Tb 4Gb Ram 2 core processor ( not the best but ok ) with a great network PRIVATE DEDICATED server, very good support and for 5 euro or close to.. Use it for sftp backups and run a few sites if you wish. The options llia mentioned are great but not on a dedicated server and you will not be able to run websites on or have full control. Also 100Gb FREE off server backup space.
5€ 1TB? Dont see it…
