It never occurred to me to do that, historically and with little to no knowledge I’ve used https://server.example.com to access Webmin, and so felt I needed an SSL cert for that FQDN
So, the way i setup a LE cert for the FQDN was to add server.example.com to ‘domain names listed here’ in the LE SSL Certificate page for example.com
I know you’ve changed the way you’re going about things, but that’s how I did it - no guarantee it was the right way though.
Yeah, don’t do that. I did this since my host went under and I didn’t have a FQDN. I’ve been using Linux for years so I figured I could resolve it later. Every time I try to fix it it breaks something else (usually email).
It does. It’s just so different from my web server setups going back as far as I can remember, it seemed kind of odd to not have a cert to secure the server’s FQDN. With my new setup and how I’ve changed how everything is done though, it’s not much of an issue.
