Hi all
I installed a fresh Virtualmin on a fresh server 3 days ago. Then, I created some users and logged-in using ProFTP successfully.
Starting from today, ProFTP no longer accept logins. The messages I see in my FTP client:
220 FTP Server ready.
23>USER uxuxux
23>331 Password required for uxuxux
23>PASS (hidden)
23>530 Login incorrect.
23>Client closed the connection.
Obviously, username and passwords are correct.
I also totally disabled CSF.
Please help, because I have no more places where to check. I tried to check almost all
Thank you
Carlo
Eric
October 24, 2014, 4:59pm
2
Are you by chance using CentOS?
If so, what is the output of this command:
rpm -qa | grep proftp
Hello!
Yes, CentOS 6.5 64bit
The result is:
proftpd-1.3.4a-1.el6.rf.x86_64
Thank you
Eric
October 24, 2014, 6:05pm
4
Aha, it looks like you have a version of ProFTPd that came from a third party repository… that’s likely the cause of the problem you’re seeing.
There’s more information about that here in the section named “Why does PHP / ProFTPd no longer work after performing updates? (I’m using CentOS, and enabled third party repositories)”:
http://virtualmin.com/documentation/system/faq
Hello
I installed just “rsnapshot”. Maybe this caused the problem?
I can ensure you that I installed nothing more!
I hope that I will find a solution in the mentioned document.
Thank you!
