Bandwidth Monitor shows virtual host over its bandwidth limit... still enabled...
It seams that virtual min is not automatically disabling and enabiling hosts when they reach and drop below their bandwidth limits.
It says in the control panel they are over the limit but they are still enabled… any help?
N.B. Yes the option “Disable if over limit bandwidth?” for the virtual host has “Yes” selected.
Thanks.
If you have the disable if over limit option set, than it may be a bug – I’d recommend filing a bug report using the Support link above.
Thanks,
