OK more and more with MX SPF DMARC DKIM setup some problems mail forwarding, mailforms on sites used and so on.
Causing backscatter, blacklists , resources abuse and …
Maybe a idea to use some out of this topic?
I mean dovecot api / push notifications options to be build in virtualmin , if a user / virtualserver whatever has such setup / problem with a mailaccount , the SERVER admin becomes pushed notifications pointing out when a problem and where / user / emailaccount exists.
Much better solution than taking care of log files searching for … ?
Am i right and is such thing possible for Virtualmin / Webmin developpers. ?
So more pro active notification you can react to (or even automatic) disable ones emailaccount to prevent blacklisting / backscatter …
I mean:
IN emailaccount where xx amount of email message’s abuse / email delivery failed and such things if value xx against time yy reach some point a push notification to serveradmin /root whatever mailadres with enough info which emailaccount / user …
Then also if reaching xx mails(pushed) within yy time disable that email account automaticly that is causing troubles.
So not the normal account settings limits for emailaccount , but troubled warnings / pushed limits then disable.
(this is then also could be nice indicator for hacked emailaccounts from users , and …)
