Backblaze Module Error or issue
Webmin version 2.303
Virtualmin version 7.30.8 Pro
Webserver version Apache version 2.4.58
I currently have S3 Account setup which if I recall correctly is available in the GPL version so this allows me to use this to backup to Backblaze B2. I now have a PRO licence and was trying to set up Backblaze via the CloudProviders module but am not 100% clear it loos like I havent got it setup correctly and I may be missing some packages.
Whats not 100% clear is when you setup a new key you get 2 keys a KeyID and an application key but the Backblaze module seems to require the same but am getting the error message below. I have double checked the credentials.
Failed to save cloud storage provider : Login to Backblaze failed : Backblaze command b2, b2-linux or backblze-b2 is not installed
You should help Virtualmin locate the BackBlaze command by using the “System Settings ⇾ Virtualmin Configuration: Backup and Restore” page and its “Full path to b2 command for Backblaze” option.
So I visited https://www.backblaze.com/docs/cloud-storage-command-line-tools and followed the instructions there and was able to install & chmod /usr/bin and it’s now working as expected :wink:
