Hi, i installed geoip and i had problems because keep saying
Error: Plugin init for plugin ‘geoip’ failed with return code: Error opening geoip.dat at (eval 5) line 4973, line 717.
(A module required by plugin might be missing).
Setup (’/etc/awstats/awstats.dnd.arkalseif.info.conf’ file, web server or permissions) may be wrong.
i go to the /etc/awstats/awstats.dnd.arkalseif.info.conf and then i find that its only adds
LoadPlugin=geoip
so i change to this LoadPlugin=geoip GEOIP_STANDARD /usr/share/GeoIP/GeoIP.dat and work
but if i go to awstats configuration and then i click on the Save Save and Re-Generate Report button, it put it this at the end of the file
#LoadPlugin=geoip GEOIP_STANDARD /usr/share/GeoIP/GeoIP.dat
LoadPlugin=geoip
anybody know why this happen? i have to do change awstats file on every domain manually? it happens with every new domain that i dont change the .conf file
