AWStats and Webalizer
Is it possible to change the location of the folders /awstats-icon /awstatsicons /icon /stats located by default in /home/domainname/public_html? And where can I see the report of Webalizer? Now I can see only the report of AWStats ( in Logs and Reports -> View AWstats Report). Instead in Logs and Reports -> Webalizer Report I can see only a page with “Edit Log File”, but not the Report with statistics. Thank you.
Virtualmin -> Features and Plugins -> AWstats and click the “Configure” option to change the default path of installation.
Webalizer access is at ${DOM}/stats. So if your site is “example.com” you would go to example.com/stats and log in with the same username/password you used to create the virtual server.
Thank you, landjea. OK about AWstats, but I can change the location of the three folders in *.conf files located in /etc/awstats because I didn’t find nothing useful for my target in Virtualmin -> Features and Plugins -> AWstats -> Configure option. Nothing to do for Webalizer. In “domainname”/stats the login fails, I don’t know why. In Webmin -> Server -> Webalizer Logfile Analysis -> Edit Log File if I click on Generate Report, this error message appears:
“Webalizer V2.01-10 (Linux 2.6.32-5-amd64) locale: C
Using logfile /var/log/virtualmin/“domainname”_access_log.1.gz (gzip-clf)
Using default GeoIP database
Using logfile /var/log/virtualmin/“domainname”_access_log (clf)
… Webalizer failed! See the output above for details”
So I can’t see the Webalizer Report. Is it possible to fix it?
Bump.
Bumping this:
