This is a public mail server. I prefer to don’t touch configurations too much…
This is my procmail configuration:
LOGFILE=/var/log/procmail.log
TRAP=/etc/webmin/virtual-server/procmail-logger.pl
:0wi
VIRTUALMIN=|/etc/webmin/virtual-server/lookup-domain.pl --exitcode 73 $LOGNAME
EXITCODE=$?
:0
- ?/usr/bin/test “$EXITCODE” = “73”
/dev/null
:0
- ?/usr/bin/test “$VIRTUALMIN” != “”
INCLUDERC=/etc/webmin/virtual-server/procmail/$VIRTUALMIN
DEFAULT=/var/spool/mail/$LOGNAME
ORGMAIL=/var/spool/mail/$LOGNAME
DROPPRIVS=yes
:0
$DEFAULT
:0
- ^X-Spam-Status: Yes
/dev/null
And this is my sendmail configuration:
divert(-1)dnl
dnl #
dnl # This is the sendmail macro config file for m4. If you make changes to
dnl # /etc/mail/sendmail.mc, you will need to regenerate the
dnl # /etc/mail/sendmail.cf file by confirming that the sendmail-cf package is
dnl # installed and then performing a
dnl #
dnl # make -C /etc/mail
dnl #
include(/usr/share/sendmail-cf/m4/cf.m4')dnl VERSIONID(
setup for linux’)dnl
OSTYPE(linux')dnl dnl # dnl # Do not advertize sendmail version. dnl # define(
confSMTP_LOGIN_MSG’, $j $b')dnl dnl # dnl # default logging level is 9, you might want to set it higher to dnl # debug the configuration dnl # define(
confLOG_LEVEL’, 12')dnl dnl # dnl # Uncomment and edit the following line if your outgoing mail needs to dnl # be sent out through an external mail server: dnl # dnl define(
SMART_HOST’, smtp.your.provider')dnl dnl # define(
confDEF_USER_ID’, ``8:12’’)dnl
dnl define(confAUTO_REBUILD')dnl define(
confTO_CONNECT’, 1m')dnl define(
confTRY_NULL_MX_LIST’, True')dnl define(
confDONT_PROBE_INTERFACES’, True')dnl define(
PROCMAIL_MAILER_PATH’, /usr/bin/procmail')dnl define(
ALIAS_FILE’, /etc/aliases')dnl define(
STATUS_FILE’, /var/log/mail/statistics')dnl define(
UUCP_MAILER_MAX’, 2000000')dnl define(
confUSERDB_SPEC’, /etc/mail/userdb.db')dnl define(
confPRIVACY_FLAGS’, authwarnings,novrfy,noexpn,restrictqrun')dnl dnl # dnl # The following allows relaying if the user authenticates, and disallows dnl # plaintext authentication (PLAIN/LOGIN) on non-TLS links dnl # define(
confAUTH_OPTIONS’, A')dnl dnl # <added> TRUST_AUTH_MECH(
DIGEST-MD5 CRAM-MD5 LOGIN PLAIN’)dnl
define(confAUTH_MECHANISMS',
dnl #
dnl #
dnl # PLAIN is the preferred plaintext authentication method and used by
dnl # Mozilla Mail and Evolution, though Outlook Express and other MUAs do
dnl # use LOGIN. Other mechanisms should be used if the connection is not
dnl # guaranteed secure.
dnl # Please remember that saslauthd needs to be running for AUTH.
dnl #
dnl TRUST_AUTH_MECH(EXTERNAL DIGEST-MD5 CRAM-MD5 LOGIN PLAIN')dnl dnl define(
confAUTH_MECHANISMS’, EXTERNAL GSSAPI DIGEST-MD5 CRAM-MD5 LOGIN PLAIN')dnl dnl # dnl # Rudimentary information on creating certificates for sendmail TLS: dnl # cd /etc/pki/tls/certs; make sendmail.pem dnl # Complete usage: dnl # make -C /etc/pki/tls/certs usage dnl # dnl define(
confCACERT_PATH’, /etc/pki/tls/certs')dnl dnl define(
confCACERT’, /etc/pki/tls/certs/ca-bundle.crt')dnl dnl define(
confSERVER_CERT’, /etc/pki/tls/certs/sendmail.pem')dnl dnl define(
confSERVER_KEY’, /etc/pki/tls/certs/sendmail.pem')dnl dnl # dnl # This allows sendmail to use a keyfile that is shared with OpenLDAP's dnl # slapd, which requires the file to be readble by group ldap dnl # dnl define(
confDONT_BLAME_SENDMAIL’, groupreadablekeyfile')dnl dnl # dnl define(
confTO_QUEUEWARN’, 4h')dnl dnl define(
confTO_QUEUERETURN’, 5d')dnl dnl define(
confQUEUE_LA’, 12')dnl dnl define(
confREFUSE_LA’, 18')dnl define(
confTO_IDENT’, 0')dnl dnl FEATURE(delay_checks)dnl FEATURE(
no_default_msa’, dnl')dnl FEATURE(
smrsh’, /usr/sbin/smrsh')dnl FEATURE(
mailertable’, hash -o /etc/mail/mailertable.db')dnl FEATURE(
virtusertable’, hash -o /etc/mail/virtusertable.db')dnl FEATURE(redirect)dnl FEATURE(always_add_domain)dnl FEATURE(use_cw_file)dnl FEATURE(use_ct_file)dnl dnl # dnl # The following limits the number of processes sendmail can fork to accept dnl # incoming messages or process its message queues to 20.) sendmail refuses dnl # to accept connections once it has reached its quota of child processes. dnl # dnl define(
confMAX_DAEMON_CHILDREN’, 20')dnl dnl # dnl # Limits the number of new connections per second. This caps the overhead dnl # incurred due to forking new sendmail processes. May be useful against dnl # DoS attacks or barrages of spam. (As mentioned below, a per-IP address dnl # limit would be useful but is not available as an option at this writing.) dnl # dnl define(
confCONNECTION_RATE_THROTTLE’, 3')dnl dnl # dnl # The -t option will retry delivery if e.g. the user runs over his quota. dnl # FEATURE(local_procmail,
‘, procmail -t -Y -a $h -d $u')dnl FEATURE(
access_db’, hash -T<TMPF> -o /etc/mail/access.db')dnl FEATURE(
blacklist_recipients’)dnl
EXPOSED_USER(root')dnl dnl # dnl # For using Cyrus-IMAPd as POP3/IMAP server through LMTP delivery uncomment dnl # the following 2 definitions and activate below in the MAILER section the dnl # cyrusv2 mailer. dnl # dnl define(
confLOCAL_MAILER’, cyrusv2')dnl dnl define(
CYRUSV2_MAILER_ARGS’, FILE /var/lib/imap/socket/lmtp')dnl dnl # dnl # The following causes sendmail to only listen on the IPv4 loopback address dnl # 127.0.0.1 and not on any other network devices. Remove the loopback dnl # address restriction to accept email from the internet or intranet. dnl # dnl # dnl # The following causes sendmail to additionally listen to port 587 for dnl # mail from MUAs that authenticate. Roaming users who can't reach their dnl # preferred sendmail daemon due to port 25 being blocked or redirected find dnl # this useful. dnl # dnl DAEMON_OPTIONS(
Port=submission, Name=MSA, M=Ea’)dnl
dnl #
dnl # The following causes sendmail to additionally listen to port 465, but
dnl # starting immediately in TLS mode upon connecting. Port 25 or 587 followed
dnl # by STARTTLS is preferred, but roaming clients using Outlook Express can’t
dnl # do STARTTLS on ports other than 25. Mozilla Mail can ONLY use STARTTLS
dnl # and doesn’t support the deprecated smtps; Evolution <1.1.1 uses smtps
dnl # when SSL is enabled-- STARTTLS support is available in version 1.1.1.
dnl #
dnl # For this to work your OpenSSL certificates must be configured.
dnl #
dnl DAEMON_OPTIONS(Port=smtps, Name=TLSMTA, M=s')dnl dnl # dnl # The following causes sendmail to additionally listen on the IPv6 loopback dnl # device. Remove the loopback address restriction listen to the network. dnl # dnl DAEMON_OPTIONS(
port=smtp,Addr=::1, Name=MTA-v6, Family=inet6’)dnl
dnl #
dnl # enable both ipv6 and ipv4 in sendmail:
dnl #
dnl DAEMON_OPTIONS(Name=MTA-v4, Family=inet, Name=MTA-v6, Family=inet6') dnl # dnl # We strongly recommend not accepting unresolvable domains if you want to dnl # protect yourself from spam. However, the laptop and users on computers dnl # that do not have 24x7 DNS do need this. dnl # dnl # FEATURE(
accept_unresolvable_domains’)dnl
dnl #
dnl #
dnl # Also accept email sent to “localhost.localdomain” as local email.
dnl #
LOCAL_DOMAIN(localhost.localdomain')dnl dnl # dnl # The following example makes mail from this host and any additional dnl # specified domains appear to be sent from mydomain.com dnl # dnl MASQUERADE_AS(
mydomain.com’)dnl
dnl #
dnl # masquerade not just the headers, but the envelope as well
dnl #
dnl FEATURE(masquerade_envelope)dnl
dnl #
dnl # masquerade not just @mydomainalias.com, but @*.mydomainalias.com as well
dnl #
dnl FEATURE(masquerade_entire_domain)dnl
dnl #
dnl MASQUERADE_DOMAIN(localhost)dnl
dnl MASQUERADE_DOMAIN(localhost.localdomain)dnl
dnl MASQUERADE_DOMAIN(mydomainalias.com)dnl
dnl MASQUERADE_DOMAIN(mydomain.lan)dnl
MAILER(smtp)dnl
MAILER(procmail)dnl
dnl MAILER(cyrusv2)dnl
DAEMON_OPTIONS(Port=smtp, Name=MTA')dnl FEATURE(
dnsbl’, cbl.abuseat.org',
‘, "550 Mail from " $&{client_addr} " refused. Rejected for bad WHOIS info on IP of your SMTP server " in http://cbl.abuseat.org/lookup.cgi "') INPUT_MAIL_FILTER(
ratelimit-filter’, S=local:/var/run/milter-greylist/milter-greylist.sock') define(
confINPUT_MAIL_FILTERS’,ratelimit-filter') define(
confMILTER_MACROS_CONNECT’,j, {if_addr}') define(
confMILTER_MACROS_HELO’,{verify}, {cert_subject}') define(
confMILTER_MACROS_ENVFROM’,i, {auth_authen}') define(
confMILTER_MACROS_ENVRCPT’,`{greylist}’)
What do you think about these configurations?
Thanks.
