I occasionally find that some files residing in the public_html directory will be owned by “root” instead of “username”
This will be because I run scripts to upgrade certain files and also because I tend to work on some files and upload them as “root”
Thanks for pointing out that the mail folders have different usernames - phew!
I am hoping that there would be a simple script to simply run through all the files contained in “public_html” and make sure the user and group permissions are correct - perhaps on a daily basis.
