Not sure what’s happened, but I’ve suddenly run into an issue with my Virtualmin config stating MySQL is not running.
Digging deeper, I also notice an error when starting the system which has to do with AppArmor not starting.
The error using journalctl -b is:
Oct 16 21:50:43 server systemd[1]: apparmor.service: Control process exited, code=exited status=123
Oct 16 21:50:43 server systemd[1]: Failed to start LSB: AppArmor initialization.
Oct 16 21:50:43 server systemd[1]: apparmor.service: Unit entered failed state.
Oct 16 21:50:43 server systemd[1]: apparmor.service: Failed with result 'exit-code'.
and viewing the AppArmor status I get:
● apparmor.service - LSB: AppArmor initialization
Loaded: loaded (/etc/init.d/apparmor; bad; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2017-10-16 22:02:41 BST; 6s ago
Docs: man:systemd-sysv-generator(8)
Process: 7267 ExecStart=/etc/init.d/apparmor start (code=exited, status=123)
Oct 16 22:02:40 server apparmor[7267]: * Starting AppArmor profiles
Oct 16 22:02:40 server apparmor[7267]: Found reference to variable HOME, but is never declared
Oct 16 22:02:40 server apparmor[7267]: Skipping profile in /etc/apparmor.d/disable: usr.sbin.rsyslogd
Oct 16 22:02:41 server apparmor[7267]: Skipping profile in /etc/apparmor.d/disable: usr.sbin.rsyslogd
Oct 16 22:02:41 server apparmor[7267]: …fail!
Oct 16 22:02:41 server systemd[1]: apparmor.service: Control process exited, code=exited status=123
Oct 16 22:02:41 server systemd[1]: Failed to start LSB: AppArmor initialization.
Oct 16 22:02:41 server systemd[1]: apparmor.service: Unit entered failed state.
Oct 16 22:02:41 server systemd[1]: apparmor.service: Failed with result ‘exit-code’.
Could someone let me know how to fix this or give me a hand to try to please as I don’t really want to have to start over; I wish there was a “repair” function for Virtualmin install ;(
Thanks again
Server OS: Ubuntu 16.0.4.2LTS
Webmin/Virtualmin: Latest (updated daily)
Chris: Adelphia Interactive
