As a recent convert from Cpanel we’re hoping we’re just missing something simple. We’re looking to modify the apache template for the SSL version of a server. The main purpose behind this is independent logging of the SSL/Non-SSL sites. So far we have tried this in the following location:
System Settings -> Server Templates -> Edit Server Template -> Apache website
and adding the following to the config;
ErrorLog /var/log/domlogs/${USER}/${DOM}${IF-SSL}ssl${ENDIF-SSL}error_log
CustomLog /var/log/domlogs/${USER}/${DOM}${IF-SSL}ssl${ENDIF-SSL}access_log combined
The part that never seems to work when rebuilding the config is the IF-SSL piece.
A couple of questions:
- Are we doing this correctly, both syntactically and in the correct place?
- Should deleting and re-adding the SSL server rebuild the config from scratch?
