This is my domain name: https://www.grouptoall.com . I recently purchased this domain name and want to connect with my server. when i was trying to connect with my server, website wont open. Then i am try to find the issue then i find apache is not running. Please help me to start apache server.
There seem to alot of things wrong there, how did you install Virtualmin? Did you use the Automated script or manual method? Maybe try Virtualmin - System Settings - Re-run install wizard.
Else you will need to correct the errors in the log. The fact its saying your missing Config variable points to a bad install.
You may need to get staffs help with this one. A normal install should work fine unless you have manually changed things. By the docs your OS is support using the standard script at https://software.virtualmin.com/gpl/scripts/install.sh is that the one you used?
