Apache Error (104)Connection reset by peer and (32)Broken pipe
Hello, first of all, sorry for my bad english, I hope to be able to make me understand.
It’s a year I’ve this annoying problem. I can’t find a solution.
When the virtual server have a large amount of simultaneous visitors, two out of tree, the visitor get an internal error blank page ( the default page of apache ).
And the error in the log is the following:
Sometime is
[Fri Jun 30 12:41:02.066472 2017] [fcgid:warn] [pid 14700] (104)Connection reset by peer: [client …] mod_fcgid: error reading data from FastCGI server, referer: http://…/
and other time is
[Fri Jun 23 10:57:38.994370 2017] [fcgid:warn] [pid 13399] (32)Broken pipe: [client …] mod_fcgid: ap_pass_brigade failed in handle_request_ipc function, referer: http://…/
I’ve tried editing the PHP_FCGI_MAX_REQUESTS and it doesn’t solve the problem. I tried using a big value and using 0, same result.
I’ve tried to edit the “FcgidBusyTimeout” and “FcgidIOTimeout” and nothing changed.
Tried to use “chattr” on fcgi file in /home/user/fcgi-bin
It is started on php 5.x, now i’m using php7.0 and the result isn’t changed.
I’ve tried to switch from fcgid, to apache_mod_php.
I get a browser error “The page you are loading don’t work” instead of the Internal Error page, and it not generate any logs.
I don’t know what else i can try.
Any ideas ?
I’m on Debin 8.6 and Virtualmin 1.831
Thanks for all the help
