Checking Configuration now doesn’t prompt the error anymore…
My sites are working fine, also, as before…
**The status of your system is being checked to ensure that all enabled features are available and properly configured ..**
Your system has 3.82 GiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB
BIND DNS server is installed, however, the default primary DNS server ns1-39.azure-dns.com does not resolve to an IP address
Mail server Postfix is installed and configured
Postfix is configured to support per-domain outgoing IP addresses
Apache is installed
Apache supports HTTP/2 on your system
The following CGI script execution modes are available : suexec fcgiwrap
The following PHP execution modes are available : fpm fcgid cgi
The following PHP versions are available : 5.6.40 (/bin/php5.6), 7.0.33 (/bin/php7.0), 7.1.33 (/bin/php7.1), 7.2.34 (/bin/php7.2), 7.3.33 (/bin/php7.3), 7.4.33 (/bin/php-cgi7.4), 8.1.27 (/bin/php-cgi8.1), 8.2.17 (/bin/php-cgi8.2), 8.3.4 (/bin/php-cgi8.3)
The following PHP-FPM versions are available : 5.6.40 (php5.6-fpm) 7.0.33 (php7.0-fpm) 7.1.33 (php7.1-fpm) 7.2.34 (php7.2-fpm) 7.3.33 (php7.3-fpm) 7.4.33 (php7.4-fpm) 8.1.27 (php8.1-fpm) 8.2.17 (php8.2-fpm) 8.3.4 (php8.3-fpm)
Apache is configured to host SSL websites
MariaDB 10.3.39 is installed and running
Logrotate is installed
SpamAssassin and Procmail are installed and configured for use
ClamAV is installed and assumed to be running
Plugin AWStats reporting is installed
Plugin Protected web directories is installed
Using network interface eth0 for virtual IPs
Default IPv4 address for virtual servers is ***.***.***.***
Detected external IPv4 address is ***.***.***.***
Quotas are not enabled on the filesystem / which contains home directories under /home and email files under /home. Quota editing has been disabled
All commands needed to create and restore backups are installed
The selected package management and update systems are installed
Chroot jails are available
**.. your system is ready for use by Virtualmin**
These are the steps I followed…
root@myhost:~# sudo apt-get install php7.0-fpm
Reading package lists... Done
Building dependency tree
Reading state information... Done
php7.0-fpm is already the newest version (7.0.33-68+ubuntu20.04.1+deb.sury.org+2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@myhost:~# sudo a2dismod php7.0
Module php7.0 already disabled
root@myhost:~# sudo a2enconf php7.0-fpm
Enabling conf php7.0-fpm.
To activate the new configuration, you need to run:
systemctl reload apache2
root@myhost:~# sudo a2enmod proxy_fcgi
Considering dependency proxy for proxy_fcgi:
Module proxy already enabled
Module proxy_fcgi already enabled
root@myhost:~# sudo apt-get install php7.1-fpm
php7.1-fpm is already the newest version (7.1.33-56+ubuntu20.04.1+deb.sury.org+1).
root@myhost:~# sudo a2dismod php7.1
Module php7.1 already disabled
root@myhost:~# sudo a2enconf php7.1-fpm
Enabling conf php7.1-fpm.
root@myhost:~# sudo apt-get install php7.2-fpm
php7.2-fpm is already the newest version (7.2.34-43+ubuntu20.04.1+deb.sury.org+1).
root@myhost:~# sudo a2dismod php7.2
Module php7.2 already disabled
root@myhost:~# sudo a2enconf php7.2-fpm
Enabling conf php7.2-fpm.
root@myhost:~# sudo apt-get install php7.3-fpm
php7.3-fpm is already the newest version (7.3.33-14+ubuntu20.04.1+deb.sury.org+1).
root@myhost:~# sudo a2dismod php7.3
Module php7.3 already disabled
root@myhost:~# sudo a2enconf php7.3-fpm
Enabling conf php7.3-fpm.
root@myhost:~# sudo a2dismod mpm_prefork
Module mpm_prefork disabled.
systemctl restart apache2
root@myhost:~# sudo a2enmod mpm_event
Considering conflict mpm_worker for mpm_event:
Considering conflict mpm_prefork for mpm_event:
Enabling module mpm_event.
root@myhost:~# sudo a2enmod ssl
Considering dependency setenvif for ssl:
Module setenvif already enabled
Considering dependency mime for ssl:
Module mime already enabled
Considering dependency socache_shmcb for ssl:
Module socache_shmcb already enabled
Module ssl already enabled
root@myhost:~# sudo a2enmod http2
Module http2 already enabled
root@myhost:~# sudo systemctl restart apache2
My only issue is that in PHP Configuration I still see the following lines…
Any option to remove them?
