Apache Configuration for Proxypass
OK, I am not an Apache person; mostly use nginx. I need to set up the following in Virtualmin to get rocketchat working. I have looked around the GUI but not sure where I should set what or if I should just edit the directive manually and if so, what do I put where.
<VirtualHost *:80>
        ServerAdmin admin@example.com
        ServerName subdomain.your-domain.com
        ServerAlias www.subdomain.your-domain.com
        <Location />
                Order allow,deny
                Allow from all
                ProxyPass http://localhost:3000/
                ProxyPassReverse http://localhost:3000/
        </Location>
</VirtualHost>
<VirtualHost *:443>
        <Location />
                Order allow,deny
                Allow from all
        </Location>
        SSLCertificateFile /etc/letsencrypt/live/subdomain.your-domain.com/cert.pem
        SSLCertificateKeyFile /etc/letsencrypt/live/subdomain.your-domain.com/privkey.pem
        Include /etc/letsencrypt/options-ssl-apache.conf
        SSLCertificateChainFile /etc/letsencrypt/live/subdomain.your-domain.com/chain.pem
</VirtualHost>
very simple proxypass :
<VirtualHost *:443>
ProxyPass / http://localhost:3000/
ProxyPassReverse / http://localhost:3000/
I must not have done it correctly because it ended up bonking the cert for the regular domain. I had applied a separate cert to the sub domain. I removed the sub domain and it bonked webmin; had to edit minserv.conf and remove two lines relating to the sub domain certs before webmin would start.
It is very simple. Go to edit the directive, remove everything and paste in the following for the port 80 part of the domain:
        <Location />
                Order allow,deny
                Allow from all
        </Location>
then do the same for the port 443 part of the domain but include the ssl cert info
        <Location />
                Order allow,deny
                Allow from all
        </Location>
then restart apache and you are good to go. You can set up a redirect from http to https as well.
That worked but then I was unable to apply an Let’s Encrypt cert to the sub domain.
I deleted and then recreated the sub domain. I then requested a cert from Let’s Encrypt. Once that was in place I simply edited the directive for the ssl website and added only the location block and left everything else as it was. It works. I will see how updating the cert goes when that time comes. I am actually thinking that buying certs is the way to go; this constant renewing from Let’s Encrypt stinks; they could make it at least six months. There are cheaper certs on the market now and not worrying about the certs for a whole year is nice. People run scare when they see that big red warning on their browser window.
