Hi all if some one could give advice it would be great.
running on Dedi server
CPUIntel® Core™ i5-3570S CPU @ 3.10GHz
Number :4Cache :6144 KBSpeed :3424 MHz
RAM2 x 8192 MB
CentOS Linux 7.4.1708
Basically all was fine last night but i had no space left on root folder so cleaned old files like old kernels and .giz files.
In order to auto update a couple of files as normal.
now i see that the Apche and MySQL db is down and wont restart.
the errors i get are
# apachectl configtest (2)No such file or directory: AH02291: Cannot access directory '/etc/httpd/logs/' for main error log (2)No such file or directory: AH02291: Cannot access directory '/var/log/virtualmin/' for error log of vhost defined at /etc/httpd/conf/httpd.conf:771 (2)No such file or directory: AH02291: Cannot access directory '/var/log/virtualmin/' for error log of vhost defined at /etc/httpd/conf/httpd.conf:692 (2)No such file or directory: AH02291: Cannot access directory '/var/log/virtualmin/' for error log of vhost defined at /etc/httpd/conf/httpd.conf:599 (2)No such file or directory: AH02291: Cannot access directory '/var/log/virtualmin/' for error log of vhost defined at /etc/httpd/conf/httpd.conf:507 (2)No such file or directory: AH02291: Cannot access directory '/var/log/virtualmin/' for error log of vhost defined at /etc/httpd/conf/httpd.conf:432 (2)No such file or directory: AH02291: Cannot access directory '/var/log/virtualmin/' for error log of vhost defined at /etc/httpd/conf/httpd.conf:361 (2)No such file or directory: AH02291: Cannot access directory '/etc/httpd/logs/' for error log of vhost defined at /etc/httpd/conf.d/ssl.conf:56 AH00014: Configuration check failedthe file ‘/etc/httpd/logs/’
is there so very odd??
also the Mysql is showing errors.
Failed to start database :
Redirecting to /bin/systemctl start mariadb.service
Job for mariadb.service failed because the control process exited with error code. See "systemctl status mariadb.service" and "journalctl -xe" for details.
and
MySQL is not running on your system - database list could not be retrieved.
The full MySQL error message was : DBI connect failed : Can’t connect to local MySQL server through socket ‘/var/lib/mysql/mysql.sock’ (2)
hope that helps
I do still have webmin and SSH login if helps
thanks
